convert 1/8 mile to 1/4 mile times? estimate?
Old 09-27-2008, 09:17 AM
flynlow3's Avatar
Default convert 1/8 mile to 1/4 mile times? estimate?
I ran for the very first time last night. And even though the track was horrible and I couldnt drive i would still like to know what my times would convert to if it was a 1/4 mile instead of an 1/8 mile.
my 60ft: 1.92
my reaction was .9211
my 1/8 time 8.551
my 1/8 mph 85.564
Thats all i can remember. I spun 3 times during this run even with traction control on.
Old 09-27-2008, 09:58 AM
BAKED's Avatar
13.39 @106 is what the calculator said.
Old 09-27-2008, 10:19 AM
99_ls1_z28's Avatar
What calculator did you used??
Old 09-27-2008, 10:24 AM
Elite_Hot_Rod's Avatar
Most people use 1.55 as the multiplier but I use 1.57, I've found it's closer to my actual 1/4 mile times. 8.551 X 1.57=13.42.
Old 09-27-2008, 10:29 AM
99_ls1_z28's Avatar
But how do you calculate speed??
Old 09-27-2008, 10:36 AM
there's a calculator for that also, do a search.
Old 09-27-2008, 11:32 AM
flynlow3's Avatar
thanks guys! now i know how far im off from my goals. Its mostly driver and traction issues. The car has the power. I just need to get it to the ground and keep it there!
Old 09-27-2008, 02:40 PM
Navy David SS's Avatar
1/8 Mile Conversion
Here's the link that will do both 1/8 to 1/4 and MPH
David
Old 10-07-2008, 09:44 PM
FlashLCD33's Avatar
^^ that thing was pretty close for my car
Your 1/4 Mile ET is 12.76 seconds computed from your vehicle 1/8th ET of 8.141 seconds.
Your 1/4 Mile MPH is 103.97 MPH computed from your vehicle 1/8th MPH of 83.85 MPH.
Actual 1/4 was 12.783@105.65
Old 09-26-2009, 03:25 PM
1Bad97WS-6's Avatar
I now this is a old thread but its uses the closest or exsact times. It x's it by 1.565
Old 09-28-2009, 08:44 PM
8 second club
G&HRacing's Avatar
Old 09-28-2009, 08:53 PM
jetlag's Avatar
That graph is close... My car went 6.9 1/8 with a 11.04 1/4.
Old 09-28-2009, 09:00 PM
JonCR96Z's Avatar
When I had a stock stall that chart matches perfectly, but now that I can get out of the the better I'm a little faster in the 1/8 than the chart says based on my 1/4. Still only about .2 off, though.
Old 09-29-2009, 06:41 AM
69LT1Bird's Avatar
Almost right on for mine too.
About .08 off the list above.
60 ft - 1.760
1/8 - 7.554@97.93
1/4 - 11.703@116.08
60 ft - 7.061
1/8 - 7.52@97.80
1/4 - 11.674@114.92
Apparently hurt the motor that day, pressure in the crank case and 5 and 7 @ 85 psi. Should run good on all 8.
Quick Reply: convert 1/8 mile to 1/4 mile times? estimate?
