The Fastest LT1's on LS1TECH.com
Old 09-23-2008, 06:11 AM
1SlowFormula's Avatar
Default The Fastest LT1's on LS1TECH.com
Special thanks to JUICED96Z for compiling all this info to get the original list, now lets all
contribute to keep it updated, post your times and updates in the format below...
NOTE: PLEASE PUT IN THIS TYPE OF FORMAT AND KEEP IT SIMPLE!:
Shon Herron-11.805@113.96, 97 Z28 M6, Bolt-ons/NA/3100lbs "Bolt on Record"
We are trying something new the first post will be all the fastest Power Adder cars, and the second post will be Naturally Aspirated, if I misplaced you posting please let me know...
THE POWER ADDER LIST:
Big Rick" Intrau-8.08@176, 96 T/A, Lots of stuff, single turbo
Madman & Omahar Berry-8.55@169.9 Firebird, 380ci LT1 with GTP AFR 215s twin turbo
Chris Sikora “Z8’s”-8.928 @152.61, 383 LT1, GM LT4 Heads/Intake, Vortech YSi
jakesz28-8.957@151.60, 94 Z28, LME 383, 350 shot
Joey Kenville 9.04@150, 97 camaro, th400, 396 speedtech plate, 3100lbs.
Jeff Gilbert (SSANDTA)-9.06@151.48, 96 TA 398, D1, A3, LT1 intake, AI TFS LT1 heads , OBD1 PCM, 100 shot, 3562lbs
Spray-9.08@159.7mph, 95 Z28 383 LT1, TH-400, N20
Taner-9.08@155.07, 96 SS 399ci Harshaw Racing Engine, Full BMR suspension. Quickest and Fastest M6 F body / First LT1 6spd f-Body in the 9's.
Dave DiLuca "SLED28"-9.11@155, 396 LT1, AFR's, TNT Fogger, 3415lbs
Jason Brisson(OutlawZ) 9.20@151.1, 95 Z28 A3, CSM Race Engines 383 AFR 227's, SR cam, Single plane, TH400, 9", 3.89's, 3400 race weight, NPF single stage plate n2o
Tony Shepherd 9.28 @ 144.21 (1.33), 93 Z28 , 396 LT1, AFR 227, 3450lbs, Nitrous Outlet fogger
Jason Warren-9.3@142, 95 Z/28, 355 LT1, TH-400, LT4 TrickFlows, LT4 intake, stock crank, stock pcm w/recalibration, solid roller, 300shot, 3578lbs.
Mike Harvey(strokedz)-9.46@141, 95 camaro, 383 LT1 Ai 215 trick flow heads, Ai SR cam, Ai converted single plane intake, th350, 12 bolt, 433's, 3500# race weight. 250hp shot
Andrey Sokolov-9.48@144 94 Z28 A3 383, YSI, 190 AFR's, 9"
Dallas Castro(Frst 9 prchrgd LT1)-9.53@148, 355 w/ D1 Prochager, 3540#
Eric Rheault (Row)-9.56@140.82 385ci,AI200 heads and intake,th400,9", 250 shot, 3700#
383racecar-9.78@138.11 (1.39), 95 Camaro,A3,le2 383,custom solid roller,carbed super victor,all bolt-ons,nitrous,3500#
T/ALT1-9.83@136mph, 95 T/A, 355 LT1, 10.5.1, CC306, LE Trickflows, LT4 intake, stock injectors, 3800 PI converter, TH350, 8.8" rear, 3.55's, 175 shot, 3,450lbs
Ray@nitrous outlet-9.91@136.79 (1.45), 94 Formula, 700r4, 396/200 shot,AFR 227s, 246/254 .613/.590 112lsa, 3600 stall, 3.73's 3280lbs
Mike V. (engineermike)-9.92@146.0, 95 Z28 A3, T76GTS turbo/3750lbs
TwoFast4Lv-10.05@135, A4, DOI200, LT1 3,650lbs, nitrous
Larry Hamilton (LS1 Speed)-10.09@132.5 (1.36), Speed Inc.(SI) 396 LT1, LE HR, SI LT1 heads/intake, 4L60E/PT4000, S60/3.73, 150 shot, 3400#
Jeremy McKinney (VTEC) 10.14@131 350ci,stock shortblock,nearly stock heads,th400,9" and 150 shot, 3050#
Z28&WS6-10.19@128.9, 94 Z28 383 T-400 D1SC 10-bolt 3.73
Glenn Coates-10.27@132, 95 Z28 M6, 383 LT1, Canfield heads, solid roller, 200 NX shot
Skinnies-10.28@129.3, 1983 Rx7, lt1 with heads/cam, th400, 4.11's, 100 shot, ~2400#
Jason Spasoff (lt1camaroman93)-93 Z28 10.41@131, 383 LE LT4 Heads, Custom SR cam, TH350, stock 3.23, 100-250 shot, 3200lbs
Mike Norkavage-10.41@131.58, 95 Z28, 383, AFRs, 200 shot, 10 bolt
BOLO-10.44@130.05 1.53 94Z28, Stock shortblock, Speed Inc H/C/I, Vig3600,4.10,NX150
97blkz-10.47@128 396ci LT1, GM LT4 Heads/Intake, 3200 vig, 3.73's, MT Slicks, 150 shot, 3500lbs
Charles Obstfelder "Chased"-10.48@131, 355 RGR heads/cam, 200 shot, 4$60, 12 bolt, 3770#
Josh H. "Ponyhntr"-10.570@135.01, 96 Z28 M6, 383, AFR, ProCharger F1A
WannabeSS-10.57@133 1.65 60', 96 SS M6, LE h/c, golen 383, spray
C Man -10.59@133.53 w/ 1.52 60', 95 Z28 A4, 383/Nitrous/3740lbs
LT1nitrouZ-10.63@128.9 94 Z 383, CC306, 10 bolt, 175 shot
Z-RATED94-10.75@125mph, bolt ons, LE heads, Joe O. 222/226 cam, 140shot, stock shortblock, trans and 10 bolt.
Skinnies - 10.80@127.8 w/ 1.56 60, 1996 Formula a3, 355 STOCK heads/cam/intake/TB, 3500lbs, single T76
Chris Jones-10.88@128.06, 96 Vette LT4, Bolt-ons/LT4 Hotcam/stock heads/150 shot/3220#
Jon Beam(silver95)-10.914@121.90, '95 Formula, stock engine w/Procharger, 3400#
Kyle McKenzie (Formula383)- 10.933@129.98, 95 Pontiac Formula M6, 383 Stroker/200 shot/3600#
Kryckter-11.0@128mph, 97 TA, 355 LE1.5, 200 shot, 3600lbs, 3300ft DA
Mr_Bond-11.10@123.15, 93 Z28, 230/236 Cam, PI 3000 Stall, TNT 150 Shot, Bolt-ons, 3.73s, 3665lbs
Vaders94-11.174@123.91, 94 Z28, 355 LT1 11.1, JOE'O cam/LE2 heads, TH-350/3500 stall, 3.42's, 100 shot, 3500lbs
Shawn Ferris (3rgden92maro)-11.22@120 (1.56), 95 Formula, LTs,TD's, Th350, 4k Stall, 2860#
Blownbird355 11.35@121 w/1.57 60, 94 Form, A4,All forged,S-trim 9.5#, 1 5/8 header,3500 Stall, AI 190's, 3700#
daniel6718-11.3@118, 94 Z28, cc306, 3200 stall, 3.73, 100 shot
Sweetred95ta-11.33@118 w/1.53 60ft. LT4 Hotcam kit, bowl blended stock castings, 2.0/1.56 valves, K&N CAI, 3.42's, 3600 Vig nitrous converter, stock suspension, 100 shot NX, cut out, mail order tune.
BUILT LT1-11.34@125, 94 Z28 A4, 383 LT1, AFR 195 race readies/Comp 503 cam, 3.42's, 150 TNT Nitrous
Jason Muchmore-11.5@119, 97 Camaro, 383, 100 shot, stall, 3.73's, stock suspension, drag radials.
ZEX-Z-11.59@119, 94 Z28 Convertible A4, 4.10's, tune, Longtubes, 150 shot
blackz6sp-11.72@115.83, 95 Z28, A4, Stock LT1, 3800stall, 150 shot
Mike Stevens-11.89/119mph 1.90 60ft, 1997 m6 cam'd/100shot, bolt ons, 12 bolt
camzaro28-11.9@115, 97 Z/28 A4, bolt ons +150 shot +2200 D.A.
ToxicFormula-11.913@113.89 stock internals LT1, full interior, MT Radial, 100 wet shot, bolt-ons, 3.73 gears, CPT race built 4l60E, 3200 stall, PCMforLess tune, Suspension.
Soccerbum21-11.938@110.87 Stock rebuilt LT1, 3663 raceweight, 120 shot MT ET Street DOT slicks (26x10.5x16), Auto 2.73's.
WhyHelloOfficer-12.06@116, 94 Z28, LT4 Hot Cam Kit,PI 3000 Stall, NX Wet 100 Shot, Bolt-ons, 3.23s, 3700#
The LT1 That Could-12.241@119.93, 2.087 60', 3150 DA - 95 Z28 A4, Pacesetter LTs, TDs w/ Bullets, 3.42s, TNT 150 Shot, Stock Internal/Suspension/Converter
1_bad94camaro-12.2@114.5, 96 Z28-M6 TB, MAF, Underdrives, cam, clutch, Shortie headers, Hoosier Drags, and 75 shot
97m6formula-12.4@122, 97 Formula, M6, Cam, headers, 100 shot, sprayed at the 1/8th
93v8clone-11.772@115, 94 z28, cc503, 3500 stall, spohn rear susp, full exhaust, n/x stage 2 wet kit
...1/8th mile only PA guys...
Mike OConner (OVA1)-7.28@95.70 (1.68), 96 Z28, Perfomarbuilt LVL 2 A4/SS3600 , Comp 466 cam, 4.10s, Nano-75 shot
TravisMcGill2000-94 Ta 7.34@92 1.54 60', bolt-ons with 125 shot, 3450#
Last edited by 1SlowFormula; 09-29-2009 at 12:10 AM. Reason: updated 3rgden92maro, LS1 SPEED, and OVA1
1SlowFormula is offline
Old 09-23-2008, 06:14 AM
THE NATURALLY ASPIRATED LIST:
9.50@139 (1.24 w/rear wheels), 94 TA 383 LT1/Ai TFS 215 cc race port heads/Pro Ram intake/ FAST computer/Ed Wright tune
Ed Wright-9.91@136.51, 96TA 4L60E, 383" LT4 heads & intake/NA/3250lbs
Dave Norquest "N20Dave" 9.98 @ 137 1.47 60' naturally aspirated, manual trans 396 SB2.2headed LT1 SR 28x10.5W's 3730lb raceweight.
Glenn Waguespack-9.98@128, 65 vette, 383 eagle light weight bottom end, home ported LT1 heads, Solid Bullet roller cam, Ported LT1 Intake
95 Formula-10.39@131.6, 95 Formula M6 355, stock crank, eagle rods, ross pistons. 12.5 cr, Ported GM LT4 heads, ported/welded lt4 intake, Cam motion solid roller, 25x/26x@50, 3300 ish race weight.
Bunny Mabile-10.56@124, Late 80's Firebird, LT1, mild ported heads, Hyd Bullet roller 230@.050, 3200Lbs, 750 holley
FASTFATBOY-10.58@126,94z CPT 4L60E, solid roller 383 LT1/NA/3600lbs pumpgas, drag radials
Dave Jones-10.62@127 96 Z28 383, N/A, 3450lbs
Larry Hamilton (LS1 Speed)-10.62@126, Speed Inc.(SI) 396 LT1, LE HR, SI LT1 heads/intake, 4L60E/PT4000, S60/3.73, 3400#
Mike Acton (mdacton)-10.79@127, 383 LT1 ported stock head. 750 carb., E.B. Porting engine and heads, 3375#
Mike Comp T/A-#57-10.89@128, stock LT1 bottom end/cam, LT4 heads, 3000 stall, 3800lbs
Brady Matysek (roadtrip120)-10.93@127.05 (1.57), 94 Z28 M6, 385 LT4, Dart CNC Pro 1, Solid roller, 3240 lbs, 4900ft DA
Warren Dempsey (The Engineer) 10.977@126.9, 1997 Z28 A4, N/A Golen 396 short-block w/ AFR-195s reworked by Lloyd Elliott, Comp custom-grind SR cam, Kooks headers, 12-Bolt spool/4.30s, 3440#
alan2000t/a-10.98@123.96, 93 Formula M6 396, callies crank, JRP pistons, Lingenfelter GM LT1 H/I, Hyd cam, 12-bolt, 4.11s, 26" ET Drags, 3350#
Paul Irvin(tapout911)-11.01@120 95Z, Solid roller 383, ported stock heads, N/A
Ken Anderson-11.02@122, 95 Z28 A2, 355/Cam/Heads/NA/3350lbs
Jeff Stark(Badhawk51)-11.04@121.94, 94 Firehawk, 383, Brodix heads, FLT 4L60E, 4000 stall, 12 bolt
-PEPE--11.123@124.5, 97SS M6, LME Callies Solid Roller 396, 500 N/A rwhp.
Frank95z-11.15 119.86 95Z28 Bolt-ons/3325/Cam only
Dean Stewart-11.18@120.83 N/A, 94 Z28, 11.6 CR 383, LE3 LT4 heads, BRE 230@.050 HYD, LT4 intake, 58mm AS&M, TH400 2800 stall, 3.73, 3550#
Javier97Z28-11.18@120.33, 97 Z28 A4, 355, LE Heads/Cam, Yank PT4000, Moser 9", 4.11's
ABA383-11.23@121.18, 95 Formula 383 A4, LT1 ported heads, Joe O baby cam, Vig 3600, 12 bolt, 3.73s, suspension stuff...3600ish lbs raceweight
Matt94z-11.28@118.21, 94 Z28 TH350, 355/ MTI Heads/Joe O cam
TravisA-11.28@118.1, '94 Z28 A4/.060 LT1/AI 200cc H/C and Intake/3.73/N/A
Jason Short-11.37@126, 93 Formula M6, NA, 396ci, solid roller, AFRs, stock 10 bolt w/3.73s
quik95lt1-11.40@121.5, 355 Stock Crank/Rods 11.6:1 Pump Gas, TFS Heads, AI Cam, 4000 Vigilante, 3450#
John Trevino (Greaseymec) 11.48@118 1.58 60' NA 383 LE2 292XFI, 9" 3.89, 3600 stall, 26" MT ET Streets
timelord-11.480@115.87 (1.487), 94Z28 ABARE 396/4L60E, Ai Trickflow 215cc, Ed wright Program
tomcowle-11.481@118.98 1.502 60', 95 Camaro Bolt-ons/Auto/Fuel Injected "Bolt on Record"
Lloyd Elliott-11.541@117.4, 383, H/C, stall, 3.42, stock suspension, 3820lbs
John P. (1SlowFormula)-11.561@118.00, 95 Formula A4, Bolt-ons/NA/2835 lbs "Bolt on Record holder Sep/08 - Oct/08, short lived victory"
Chris Jones-11.650@118.76, 96 Vette LT4, Bolt-ons/LT4 Hotcam/stock heads/NA/3220lbs
IrocSS85 11.69 @114.23 on a 1.61 3:42 gears, 383, 3800 EDGE stall, 15" et streets
Josh Laitner (96LT1355z28)-11.71@118 96 Z28, M6, ported heads, cam, 9", bolt ons, N/A, 3462#
big dave-11.71@117.4, '94 Z28, Ported stock heads/846 cam/stock bottom end/~3700#
joelster 11.72@114.44, stock bottom end plus big cam, TFS heads, 5000 stall, N/A
Josh Bone (86formula)-11.75@118 (1.80), 96 Z28 M6 (different car), LE2 heads/cam, 27" Hoosiers, 3.73s, JS Performance Clutch
Nick Merrifield-11.79@113.5, 94 Z28 A4, 383
Shon Herron-11.805@113.96, 97 Z28 M6, Bolt-ons/NA/3100lbs "Bolt on Record holder 3/26/06 - 09/21/08"
AChotrod-11.881@119.44 w/ 1.896 60', Stock shortblock, LE ported stock heads & intake LE custom cam, M6 Stock clutch, cat back, DRs
Matt Brunges (StealthFormula)- 11.881@114.38, 97 WS6 A4, Stock Bottom End, LE2 H/C/I, PT4000 Stall, 3500#
James Montigny-11.892 @ 113.00mph, 93 Firehawk, LE2 Heads, LE1HL cam, SS4000, MT ETDRs. -103 DA Full street weight + 275lbs driver.
Colin91Z-11.90@118.4, N/A, 96 z28, 350ci, M6, 10 bolt, ~3500#
Brian Nelson(95Z28camaro)-11.91@111mph, 95Z28, Bolt-Ons Only, 4.11's, TH350/3000stall, 3120#
Dwayne Jennings AKA 96capricemgr 11.935@ 112.83mph 96 Caprice, A4, Advanced Induction 190cc heads and cam, stock shortblock 4100#
James Hayden (buzz12586)- 12.080@111.81, 95 Z28 A4, CC503, Full Bolt-Ons, SS4000, 3500#, 2400DA
Aaron Guerrette-12.086@113.00, 94 Z28, 383, Hotcam, Ported heads, stock valves, All bolt-ons, 2000 stall, 3.23, 3700#
PJ Palmer (strokin93z)-12.1@112, 94 Camaro, LE2 Heads, LE1HL cam, SS4000, MT DRs.
jankie93z-12.1@109 (1.67), lt4 hot cam, headers, gutted and stalled th350
big_t (aka BIGT94z)-12.251@110.22, 96 formula M6, bolt on's, 4:10's, et streets, full suspension, 3200#
Isaac C. (Street Demon2k3/NastyCamd93)- 12.26@110mph, 1.66, Built 355: LE2.2 cam, 4K RPM stall, 3.73, full bolt-on's
Mikey 97Z M6-12.39@114.27, 97 Z28 M6, NA/Bolt-ons/DIY Ported Heads/CC XE224-236/3470#
Smokedoutz28-12.3@113, 97 M6 Stock Bottom end, Stock heads, 847 cam, Bolt on's
The Big Show-12.40@115, 93 Z28, 385 w/Dominion 32 Valve Heads, Custom Cam, Single Plane, Complete Suspension, 9", Coan TH-400 w/3000 stall, 3400#
95ztrey-12.48@111.63, 95 z28, N/A le1 heads, Le2 cam, full bolt ons, 3400#, 6700DA
Tony Quadros (CamaroRacing12)-12.495@107.32, 95 Z28 A4, Bolt-ons only/NA/3356lbs
RealQuick-12.5@114mph, 95 Z28, M6, H/C
86formula-12.51@110, 96 Z28, A4, Stock converter, Full bolt ons
Psycho_Teddy-12.572@104.27, 94 Z28, A4, 383(Forged Bottom End)/LT4 Hot Cam, Spohn Suspension
Matt Hyde (OddballLt1)- 12.604@105.7 1.66 60' Full exhaust, 3600 stall and 3.73's, 3140#
Mike English (slowv696)-12.74@109, 94 Camaro, M6, LTs, LM1, CC304, 4.10s
Shawn Ferris (3rdgen92maro)-12.75@106, LTs,TD's, Th350, 4k Stall, 2860#
Dave Kiel (DLK1950)-12.76@106.9, 97 Z28, cc305/Bolt ons.
Phil D'Avanzo (zlicious94)-13.003@107.44, 94 Z28 M6, 133k stock motor, Boltons, tune, tru duals
Joe Newcomer (2XR95Z28)-13.08@102.63, 95 Z28, Stock Internals, 3200vig, CAI, Exhaust, Full weight
Travis Spence (tspence45)-13.205@105.55, 94 Z28 M6, LS1 lid conversion, LT's, TD's, DR's, MadZ28 tune
96lt1m6-13.35 105.20, bolt ons, 3004' DA
Smoke_Em-13.62@101, 95 z28, a4, MAC cat back exhaust, slp CAI, msd coil, aluminum driveshaft, ported tb, airfoil
Kevin LaBelle(KLaBZ28)-13.82@100mph, 95 Z/28, A4, 2.73's, all stock except for Lingenfelter CAI and Magnaflow CB
...1/8th mile only N/A guys...
Tracy Evans-7.145@98 1.62 60', 95 Z28, 355, stock crank, injection and pcm. A3, 12 bolt, 3420#
Darrell Popham (n2ocamaro)-7.32@94 mph (1.60), 383, LT1 ported heads/intake, custom cam, th400, 9", drag radials.
Last edited by 1SlowFormula; 09-29-2009 at 12:01 AM. Reason: Added n2ocamaro, strokin93z and updated timelord, Rick Abare, 86formula, and slowv696
Old 09-23-2008, 08:35 AM
TwoFast4Lv's Avatar
Any way to make a note if a car is active or even still together?
TwoFast4Lv is offline
Old 09-23-2008, 08:46 AM
The Engineer's Avatar
Here is my input with a 3480 DA (it would have been in the tens with better air) and 3450 race weight (me in the car). Recent best run; "11.132 @ 120.64" I also ran an 11.18 at the shoot-out.
Warren Dempsey
The Engineer is offline
Old 09-23-2008, 09:28 AM
AChotrod's Avatar
Someday I will make the list!
AChotrod is offline
Old 09-25-2008, 01:13 PM
96LT1355Z28's Avatar
Default Update me new times!
Josh Laitner-96LT1355z28 11.87 @116 96 Z28, M6, ported heads, cam, 9", bolt ons, N/A, 3490 pounds
96LT1355Z28 is offline
Old 09-25-2008, 09:15 PM
Warren Dempsey
Warren,
Can you list it in the format above please...
Old 09-25-2008, 09:18 PM
Congrats on the new time, I updated it...
Old 09-25-2008, 10:00 PM
hashtagBMW
Speed Density's Avatar
Thanks for doing this John, im sure everyone will appreciate and updated list!
Tony.
Speed Density is offline
Old 09-25-2008, 10:04 PM
Tony.
No Problem, I am on rather often so can do what I can to stay on top of it...
Old 09-26-2008, 01:48 PM
CamaroRacing12's Avatar
i love it john u are the freakin man! i love how i barely sneak in at the bottom hehe
just one small suggestion tho... maybe number them? so we dont have to count all the way down... esp for us slow losers haha
CamaroRacing12 is offline
Old 09-26-2008, 04:07 PM
timelord's Avatar
11.811@116.212 1.596 60ft - 396 LT1/4L60E N.A. 3640 lbs
timelord is offline
Old 09-26-2008, 07:03 PM
good suggestion but keepoing track of numbers make it a little more difficult when people move past others then multiple lines then need to be changed...
Old 09-26-2008, 07:04 PM
Your in...
Old 09-26-2008, 08:40 PM
LittleRedZ's Avatar
i posted this last year and never got uptaded
LittleRedZ is offline
Old 09-27-2008, 07:43 AM
jonecap's Avatar
Chris Jones-11.12@127.61, 96 Vette LT4, Bolt-ons/LT4 Hotcam/stock heads/150 shot/3220lbs
Chris Jones-11.650@118.76, 96 Vette LT4, Bolt-ons/LT4 Hotcam/stock heads/motor only pass/3220lbs
jonecap is offline
Old 09-27-2008, 07:59 AM
big dave's Avatar
big dave,
'94 Z28
11.71@117.4
Mods...Ported stock heads, 846 cam,stock bottom end,SLP shorties,borla,3200 stall, 3.73s.
3680-3720 raceweight depending on amount of gas.
big dave is offline
Old 09-27-2008, 10:31 AM
TravisA's Avatar
TravisA- 11.28@118.1 1.64 60ft N/A....94'Z28 A4 4000 Edge, .060 LT1, AI 200cc H/C and Intake,3.73
TravisA is offline
Old 09-28-2008, 09:42 PM
all updated...
Old 09-30-2008, 11:58 PM
Psycho_Teddy's Avatar
Psycho_Teddy - 12.572@104.27, 94 Z28 A4, LT1 383(Forged Bottom End), Sphon Suspension, GM LT4 Hot Cam Kit
Psycho_Teddy is offline
Quick Reply: The Fastest LT1's on LS1TECH.com
