My build (truck/C6 manifold setup)
Old 09-24-2008, 08:29 PM
  #41
ls2 bait's Avatar
ya post away with the pics! ill get around to doing one of these eventually.
Old 09-24-2008, 09:57 PM
  #42
WS6HUMMER's Avatar
Originally Posted by Silver_TransAm
Do you mind posting up a detailed pic of how the pipe goes around the a/c compressor? Just curious to see how close it is or not.
Here you go.
Old 09-24-2008, 10:08 PM
  #43
KissMySSo1's Avatar
You're going to have some boost creep issues with the way your gate is mounted. I learned that the hard way. Looks good though!
Old 09-24-2008, 10:21 PM
  #44
Tiago's Avatar
yea the angle of the wastegate is not optimal, but the fabrication skills are very good!
Old 09-25-2008, 07:39 AM
  #45
WS6HUMMER's Avatar
Originally Posted by bgblockelcamino
thanks for the pics. i look forward to seeing your results. def some good ideas you have.
Thanks.
Originally Posted by rubbersdown
where did you get your flanges for your c6 header? I know stainless works sells the truck header flanges but I am having trouble finding the c6 2 bolt header flanges.
I used a flange off a 95 toyota avalon catalytic converter, its very similar to the C6 flange except the toyota uses a flat washer style gasket & the C6 uses a steel o-ring. It seals up well.
Old 09-25-2008, 07:40 AM
  #46
WS6HUMMER's Avatar
Please explain.
Old 09-25-2008, 07:43 AM
  #47
Josh@KY-Turbo's Avatar
The waste gate needs to be mounted in such a way that it is feed (pressurized by both runs of the Charge pipe. The way you have it is getting pressureized by only one side of the charge pipe. You could put it right at the intersection of the merge and then make a quick 90* turn to move the gate for clearance.
example:
Old 09-25-2008, 07:45 AM
  #48
Pic added.
Old 09-25-2008, 07:51 AM
  #49
WS6HUMMER's Avatar
Originally Posted by Josh @ KYTP
Pic added.
Thanks, I thought of that & it does get pressure from both sides I would think. I positioned it high enough up so it would be after the merge transition, the merge is very long. The fact that I tapped into the side though I'm not sure if it will affect it, what do you think?
Old 09-25-2008, 08:02 AM
  #50
The posistion + the down ward angle of the gate is the issue. The gate needs to be horizontal with or upswept with the direction of airflow for optimum effect.
try the link below. It explains it better than I can.
http://www.turbosmartonline.com/inde...ownload&id=213
Old 09-25-2008, 09:19 AM
  #51
WS6HUMMER's Avatar
Thanks I'm just gonna bite the bullett and fill graft in a plate, block off the old spot and relocate it to the center. I dont want any problems and really appreciate you guys bringing that to my attention.
Old 09-25-2008, 10:06 AM
  #52
No problem. Feel free to PM me anytime or call if you have questions. I am more than willing to help.
Old 09-25-2008, 10:48 AM
  #53
WS6HUMMER's Avatar
Thanks! I will
Old 09-25-2008, 07:04 PM
  #54
WS6HUMMER's Avatar
The wastegate situation has been rectified. Thanks again guys, glad you caught it before it was all finished.
Old 09-25-2008, 07:21 PM
  #55
1CAMWNDR's Avatar
Your welding and fabrication skills kick ***.I will be borrowing from this project a lot if and when I get to do my own turbo.
Old 09-25-2008, 07:37 PM
  #56
Now your on the right track.
Old 09-26-2008, 09:47 AM
  #57
WS6HUMMER's Avatar
I hope it will help.
Thanks.
Old 09-27-2008, 08:32 AM
  #58
blacktransam's Avatar
god seeing your sig makes me miss my car.. great progress man..
Old 09-27-2008, 08:38 AM
  #59
WS6HUMMER's Avatar
Thanks, & nice looking car!
Old 09-27-2008, 10:26 AM
  #60
mehoffz24's Avatar
ws6HUMMER, can you please pm me when you have a chance i have a few questions for you. i tried to pm you but it would work
Quick Reply: My build (truck/C6 manifold setup)
