what is the max overbore on a stock LS1 block?
Old 08-26-2003, 07:09 PM
B18B1LS1's Avatar
Default what is the max overbore on a stock LS1 block?
Is it safe to go .010 over on a stock block WITHOUT resleeving it? It will see ALOT of spray if that makes a difference. Thanks!
Jeffrey
Old 08-26-2003, 08:23 PM
someday's Avatar
Default Re: what is the max overbore on a stock LS1 block?
if ur talking about ur '98, no, '97/'98 blocks could not be bored, and '99+ can go 10 over...
Old 08-26-2003, 09:06 PM
B18B1LS1's Avatar
well crap, that sucks...thanks for the info
Jeffrey
Old 08-26-2003, 09:15 PM
Louis's Avatar
had no problems on our 98 blocked solid roller at 12 over.
Old 08-26-2003, 11:11 PM
pekkaz's Avatar
'98 Helms manual says the block can be honed(but not bored).010 and service piston is available. I don't know what's behind everybody saying '98 can only take .005 hone. Chris Endres even puts it .004
Old 08-27-2003, 07:45 AM
Ragtop 99's Avatar
I'd go only .005 over with heavy spray. The extra displacement is nothing and you never know when you'll be rebuilding it again and need another .005 for another hone.
Old 08-27-2003, 08:09 AM
Solid346's Avatar
so you are saying that a 98 block cant be honed to 3.905 bore?!?!!?
Old 08-27-2003, 11:20 AM
Louis's Avatar
I agree, but on a max effot, custom piston car- why not
Old 08-27-2003, 03:06 PM
B18B1LS1's Avatar
Sweet, that sounds much better, thanks guys!
Jeffrey
Quick Reply: what is the max overbore on a stock LS1 block?
