How can read a cam card
Old 05-14-2008, 08:20 PM
lt1camaro95's Avatar
Default How to read a cam card?
I have a cam card that came with my 408 engine but I have no clue on how to read this thing. Its a comp cam and here are the numbers. Any info would be appreciated. The card also has Vegeance Racing listed on the specs.
Part #54-000-11
Vengeance Racing
Grind# LS1 3730R/3655R HR112+4
GROSS VALVE LIFT .608 .596
DURATION @ .006 TAPPET LIFT 289 297
CAM INSTALLED AT 109 DEGREES
DURATION @ 0.50 240 244
LOBE LIFT .3580 .3510
LOBE SEPARATTION 112.0
From this I think the important parts is .608/.596 lift and .240/.244 duration and 112 separation. So is this my numbers or is there something else involved.
Old 05-14-2008, 09:25 PM
Tom@SpeedInc's Avatar
Part #54-000-11 LS1 55mm journal camshaft
Vengeance Racing
Grind# LS1 3730R/3655R HR112+4 Comp cam lobe numbers
GROSS VALVE LIFT .608 .596 Important for valve spring setup
CAM INSTALLED AT 109 DEGREES The Most important part
Quick Reply: How can read a cam card
