MS4 cam??
Old 05-08-2008, 03:15 AM
  #61
smokinponcho73's Avatar
mpfd how bout you quite bitching we understand you dislike the ms4 some of us do like it
Old 05-08-2008, 06:02 AM
  #62
black00ssFL's Avatar
Originally Posted by MPFD
Nobody said you couldn't daily drive anything, I said thats to big of a cam especially for a 346 cube. You would need at least L92 heads to flow well enough to actually use the power that cam has to offer. If its such a sweet cam and works so well for you why are you only in the 12 sec club? I've seen stock cam ls1 run in the 12's all day.
http://s191.photobucket.com/albums/z...BlackSS-pb.flv
Lol....on Nitto tires w/ STOCK suspension, and a puny 3400 stall. It's also a full weight car and I weigh about 300lbs. Just because my tag says I'm in the 12 sec club, doesn't mean I still am. Btw, temperature that night was about 65 or so on that run.
Old 05-08-2008, 06:36 AM
  #63
CaMaRo67RS355's Avatar
i love that cam i daily drove mine for 4-5 months then i got a beater just because i got tired of not so good gas mileage and didnt like putting alotta miles on my SS. the cam made 43x hp and 40x trq with all bolt ons, ported tb and ls6 intake also had 4.10 gears in the 10 bolt. it has alot of power and will like however much nitrous you wanna throw at it. i think youll like it but what are your goals for the car? what do you plan on doing with it?
Old 05-08-2008, 11:53 AM
  #64
021less's Avatar
You must not be very smart if you think that cam peaks at 6400 rpm just cause texas speed says it does. Maybe it would peak at 6400 rpm if you had no other supporting mods, and you were running a stock LS1 intake, with stock manifolds. My crappy comp cam 212/218 doesn't peak till 6100 rpm. Thats whats wrong with the racing world today, to many people with more money then brains. The LS7 also has 1.8 rockers, is the .649 lift of the MS4 with 1.8 rockers? I think not. The LS7 cam specs at .211/.230 .591 lift with 1.8 rockers. So how mild would that cam be in a LS7 again?
http://www.gmperformanceparts.com/En...2397&engCat=ls
nope, its the stock ls6 intake, slp long tubes, and ls6 heads. We run it up to 7000 and it dropped from there. Oh and for the more money than brains, i done all the work to my car myself with the exception of the tuning which vengeance racing did, and i'm a firefighter so obviously i don't have a lot of money. I work a second job to be able to afford to do stuff to the car, mr. I work for a very large corporation training many mechanics all over north america. Wonder who makes more money, fire fighter or mr. big shot??? Oh and since the ls7 has 1.8 rockers..... i believe you can change rockers to whatevery ratio you would like, correct me if i'm wrong. so why would the cam not work, just swap the 1.8's to 1.7's and there you go.
Old 05-08-2008, 04:41 PM
  #65
lemons12's Avatar
http://www.ls1.com/forums/showthread.php?t=85814
that an a4.... thats also damn good numbers for a cam with no heads..
Old 09-16-2009, 04:39 PM
  #66
tkerkes7's Avatar
Default Ms4
if i get the ms4, how many valve springs do i need to purchase? and can i keep the stock LS1 heads? wha else do i need to do?
Old 09-16-2009, 06:48 PM
  #67
miller456's Avatar
why would you bring back a year old thread? no offense but you should try the search button it works wonders. Your question is to broad and sounds like you have a lot of reading to do before you even think about a cam swap. Also springs come as a set anyway you dont just buy them separately, along with that is retainers and valve seats.
Old 06-22-2012, 09:58 PM
  #68
jbro90's Avatar
I have a 2001 z28 A4 and have been looking at the ms4 and ms3 a lot I love the way it sounds it sick. Don't really mind bucking as long as its not too much like something that air cause me to wreck but my car is completely stock right now any any help on what I should do b4 I get this cam. I know ima get ls7 littered and ls2 litter trays and ls2 double roller timing chain and tune but don't know about springs and other stuff like rollers. Are my stock rollers fine to use with this cam. Also i plain on dub frame connecters and lt headers from hooker or pacesetter. Should I do a cat back from magna flow or what really want true duals with h pipe and no cats... Any help with this would be awsome just don't want to make a bad move ya know thanks in advance guys
Old 06-23-2012, 08:59 AM
  #69
TransamGCS's Avatar
Not trying to be a dick but research would do you wonders, this is a old thread, i would suggest you go to the ls1 newbie tech and click on the so you want to be fast stickie and start their first before you even think about going with a big cam such as the ms3 or ms4
Old 04-24-2013, 07:36 AM
  #70
GMHESS7's Avatar
You can drive them on thevstreet but I wouldnt recommend it. Go with a smaller cam
Old 05-01-2013, 12:22 PM
  #71
Sommer86's Avatar
What would the MS4 on a 114 LSA be like in a daily driven LS1? even more street able?
Old 05-01-2013, 08:39 PM
  #72
Super Hulk Smash
JakeFusion's Avatar
I don't mind dockey dick cams.
I just mind folks putting LSK lobes in a street car. You will beat the **** out of your valvetrain. Lifters, valvesprings, valve tips, pushrods, rocker arms. Something is going to fail or wear out due to valve loft from such irresponsible lobes.
Stay the **** away from LSK lobes unless it's a drag car or you're going to invest in a very stout valvetrain (CHE or Jesel rockers, Morel lifters, 3/8" pushrods, hollow-stem valves, etc) and check it every 5-7k miles.
Quick Reply: MS4 cam??
