Northwest Members WA, OR, ID, MT, WY, SD, ND
Oil pressure gauge reading sky high
Old 04-18-2008, 12:43 PM
jdmavenger's Avatar
Default Oil pressure gauge reading sky high
My oil pressure indicator, both digital and mechanical, is reading 130 psi. Is that the sending unit? The car runs fine, no noise or anything. Anyone have any ideas? By the way, it's a 99 corvette.
Old 04-18-2008, 02:56 PM
B-RAD2's Avatar
See my sending unit just did the complete other way. I replaced my sending unit and it works fine now... Mine is a 99
Old 04-18-2008, 03:37 PM
Poik's Avatar
If you have a mechanical gauge hooked up that reads the same, probably not the sending unit. Did you just do an oil change? Did you use 80W90?
Old 04-18-2008, 03:53 PM
NWDragRacer's Avatar
I'm sure he's talking about the gauge on the dash and the electronic one desplayed in the DIC (Driver Information Center) when you select it.
Old 04-18-2008, 05:16 PM
crazylane's Avatar
^^^Yes that is what he is talking about...
I told him that it is probibly his oil sending unit as well. But what can I say, he is a vette owner, and he doesn't listen to well... lol
Old 07-23-2008, 02:46 PM
charlie c5's Avatar
After a hot day yesterday, I was having some heat issues, I was getting to around 244. But no running problems. Today, I take her out for a drive and notice I no longer have power steering and my oil pressure guages maxed out and was readinng 130 on the Driver info Center. WTF....
Old 07-23-2008, 06:34 PM
Move away from that hot *** state of Texas!
BTW- It's 64 degrees here today!
Old 07-24-2008, 12:34 AM
crazylane's Avatar
He no longer has problems with the oil pressure.....
Lol he's got bigger problems now..
Old 01-16-2009, 12:07 AM
Brismo7's Avatar
Exact same thing(same 130psi readings) is happening to my buddies Z06 2001 or 2002. Anyone have any ideas?
Old 01-16-2009, 12:25 AM
camaroslpss's Avatar
Be sure to relocate it since you are in there. These little guys are notorious for being D.O.A.
http://forums.corvetteforum.com/c5-t...-relocate.html
Old 01-16-2009, 08:36 AM
TwoFast4Lv's Avatar
Broken wire going to the OP Sensor
Old 01-17-2009, 02:33 PM
firehawk618's Avatar
I 2nd that motion.
If it's a SINGLE wire op sensor, then all you have to do is ground it with the key on, if the gauge reads 0 with it grounded, then bad sending unit.
If it's got more than one wire DO NOT GROUND ANY WIRES WITHOUT LOOKING AT A SCHEMATIC FIRST!
Old 01-19-2009, 02:09 AM
Brismo7's Avatar
just as a follow up fellas.
We replaced the O.P. Sender unit and that fixed his problem.
I was pretty sure it was the sensor, but i told him i would check into it for him.
Quick Reply: Oil pressure gauge reading sky high
