Old 05-06-2016, 01:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
Camaro 3.8 oil change qestion
Old 04-17-2008, 10:01 PM
purple2000_3.8's Avatar
Default Camaro 3.8 oil change qestion
how many quarts of oil does a v6 camaro hold after an oil and filter change?
Old 04-17-2008, 10:02 PM
In-Zane Moderator
ZONES89RS's Avatar
None, you changed the oil and filter.
4.5 if i remember.
Old 04-17-2008, 10:09 PM
10 Second Fun Car
jlrz28's Avatar
Check the manual....I thought it was 4 or 5 quarts?
Old 04-17-2008, 10:20 PM
01NBMT/A's Avatar
i know the LT1/LS1's are 5.5 quarts so maybe 4.5-5
CruzinCobalt's Avatar
4.5 if you use a regular filter or 5 if you use the extended filter PF 52 if i remember correctly.
Basiclly the oil filter like from a 94 chevy v6 truck will fit, but its like 2" longer.
Old 04-17-2008, 10:22 PM
JoeKnowsBaseball's Avatar
I thought the LS1 held 6.2 quarts...
and the 3.8 holds 4.5 I think. Just put in 4, start up the car till the oil pressure builds up then check it. And remember... When the oil is at the BOTTOM of the hash marks, it only takes one more quart.
Old 04-17-2008, 10:25 PM
bmxer8699's Avatar
ls1 holds 5.5
and 3.8's hold 4 depending on filter 4.5
TAEnvy's Avatar
I work in a shop and according to wrenchhead almost all the GM V6s, from the 4 whatever in the trucks to the 3.1s to the 3.4s to the 3.8s take 4.6 quarts. Put it in start the car, check the oil, and go from there.
Old 04-17-2008, 10:26 PM
01NBMT/A's Avatar
my LS1 hold 5.5 says the parts store and its between where it needs to be
Old 04-18-2008, 12:37 AM
I put in a five quart bottle it filled it good i was just asking because my oil gauge is spazzing out. it'll drop pressure everynow and then. Maybe it's building pressure or something. i drove the car for awhile and let the oil completly circulate and the dip stick is showing full, but the gauge is till acting up.
Old 04-18-2008, 09:31 AM
98FreakZ's Avatar
probably just the guage
Quick Reply: Camaro 3.8 oil change qestion
