Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Camaro Alarm Problem
Old 03-30-2008, 04:19 PM
CamaroDMD's Avatar
Default Camaro Alarm Problem
I have a 1996 Camaro 3.8L which has been my daily driver for the last 7 years and will become my brothers car in about a week.
Two nights ago, the alarm started doing something strange. When ever I lock the car...the horn beeps twice like normal, then 5 seconds later the alarm goes off with 2 horn beeps again (but slower...like if I accidentally hit the panic button) and then stops after 2. Also, the other night, I awoke to hear my car alarm going off but when I went outside the car was fine and I didn't see anyone. It has been doing this since then. Anyone have any ideas?
Old 03-30-2008, 04:27 PM
EnfuegoZ28's Avatar
Sounds like a possible short in the wiring.
Old 04-01-2008, 09:24 PM
Z ROADSTER's Avatar
Sounds like GM's infamous "LUCAS" substandard wiring products & installation proceedures to me . Anything & everything electrical in our F-bodies seems to start crappin out after about 25 to 30,000 miles . Union labor maybe ? Or a combination of both more than likely .
Old 04-22-2008, 05:16 PM
lowerthanyou00's Avatar
my 2000 z28 does the same exact ****, tho i havent diagnosed it cause its in storage, i took it out one day and it started doint that, after a year in storage it lost the fuel pump and started doin this
Old 04-22-2008, 05:19 PM
Slvr00Bird's Avatar
Maybe a bad body control module??? Just find someone who has a 3.8 that is normal and swap them out to see if it fixes it.. will take 2 minutes... its a starting place anyway..
Old 04-23-2008, 02:41 PM
hey try messing with the sensors, i had to replace the door one
Old 04-23-2008, 03:35 PM
2001NBMZ28's Avatar
Alarm going off for no reason just after arming usually points to the shock sensor - try disconnecting it temporarily and see if it stops.
Old 04-23-2008, 11:18 PM
sixvi6-camaro's Avatar
Mine was doing the same and it was the shock sensor that went bad. I just ended up leaving the shock sensor out and programing the car for keyless entry only and no alarm. No problem since.
Old 04-24-2008, 10:04 AM
CamaroDMD's Avatar
Does anyone know what it would cost to get a new shock sensor?
Old 04-24-2008, 09:19 PM
Z ROADSTER's Avatar
Probably too damn much ! Friggin General Motors electronics . Hell , you can just look at that turn signal stalk & figure how much outdated electronic's they crammed into our rides . The lights flicker , the battery gauge or voltmeter bounces back & forth , the burglar alarm is haunted . Your never completely sure if the fu*ker is gonna start or leave you stranded . But it sure is pretty,,,& fast !
Old 04-25-2008, 09:36 AM
slvr98camaro's Avatar
mine did this when the battery cable was loose, thankfully i was parked at home, because i would have had to get my car towed
Old 08-23-2008, 02:03 PM
reprobate's Avatar
Default Getting Rid of Factory Alarm
I saw that sixvi6-camaro said that he just reprogrammed his remote to not activate the alarm. How can you do that. The thing just annoys me anyway and I'm having that same two beep problem that other people have had. It's a 2000, but only has 32k miles on it.
Old 08-23-2008, 04:14 PM
Reprograming steps are in the owners manual. In the 2001 manual its in section 2-21 dunno about the 200 manual. literally its something like pull the radio fuse, key on and do the hokey pokey and press the window switch then the radio then left turn signal. its really weird doing it but it works.
the other thing you can try is mess with the shock sensor.. there is an adjustment screw on it that will sometimes solve the problem just by making it less sensitive.
Old 08-24-2008, 01:24 PM
JPCrazyLegs's Avatar
This happened to my firehawk after a big rainstorm, take off your shock sensor, open it up, its really easy, and look for moisture, take an alcohol swab and clean up any green residue. Put it back and it should work good as new.
Old 09-06-2008, 05:07 PM
TODDS93T/A's Avatar
the honks are tell you that one of the zones is open if you suspect the shocker un plug them one is up under the lower dash panel un the stering wheel the other is in the ps rear quater if the alarms goes off turn the key to ign and see how many times it flashes does your have the led in the center of the dash or somewhere elise gm had a factory and a aftermaje the dealer installed the honks are a spefic zone the dealer might know i am looking in to it
Old 08-23-2010, 03:12 AM
henshawksz's Avatar
Got A 1998 Z28 with a defective Gas Cap! This cause Same Alarm issues? Tanku2much!Tried changing battery in Fobkey/chipkey,but can't seem to put it back together!That sensor sounds like "my" issue too!
Old 02-07-2011, 09:08 AM
Kahlifornyaking's Avatar
Holy crap I am having the same issue on my 2000 z/28 and its so damn anoying! I finally got so fed up with it today that I took out the relay for the horn! Ill look into the sensor today after work. You can get them new from gmpartsdirect.com for $26.85
Old 11-28-2012, 04:07 AM
gonzalesjon1990's Avatar
LMAO had to say thanks for the laugh. I have a couple of problems im getting the p1406 and i cant make my horn while pressing the steering wheel. it works when i use the keyfob. I would appreciate any of your guys help. camaro rs 3800 v6 1996 thx
Old 12-05-2012, 11:11 AM
Floorman279's Avatar
Mine was doing this.....found a member parting the car out and got it 25 shipped...... shipping should all be the same small flat rate usps 8.00. GMparts wants 25 plus 15 shipping
Quick Reply: Camaro Alarm Problem
