GM part #s for 98-02 1LE front and rear swaybars?
Old 07-22-2003, 01:52 PM
CHRISPY's Avatar
Default GM part #s for 98-02 1LE front and rear swaybars?
Thanks guys,
I need the part numbers for the following: (98-02 cars)
32mm 1LE front swaybar
1LE Endlink kit
1LE bushings (if not included with swaybar)
1LE rear swaybar
1LE rear endlink kit
1LE bushings (If not included with swaybar)
thanks!!
Chris
Old 07-22-2003, 04:33 PM
SSixspeed's Avatar
Default Re: GM part #s for 98-02 1LE front and rear swaybars?
I don't know the part numbers, but I know that they are not all the same from 98-02. Look on 1LE.net for the part numbers.
I have a 2002 1LE and friends that own 1LE's from the other years.. we have compared part numbers and that's how we found they were not the same. If I remember right, they changed in '01 when SLP started doing the 1LE insted of GM.
Nick
2002 Camaro SS 1LE
Old 07-22-2003, 05:34 PM
felton316's Avatar
Suspension
26032907 1LE front swaybar (32mm)
10221779 1LE endlinks
10021221 1LE rear swaybar (21mm)
10262147 1LE Panhard bar
22132887 1LE front springs
22132889 1LE rear springs
52367658 1LE Front Left Lower Control Arm
22156461 1LE Front left upper Control Arm
52367659 1LE Front Right Lower Control arm
22156462 1LE Front Right upper Control arm
10288551 1LE front swaybar insulator (32mm)
10164151 1LE Lower Control Arms
22166910 1LE Rear shock insulator retainer
10009135 1LE Rear shock lower insulator
22166909 1LE Rear shock upper insulator
10235886 1LE Rear swaybar insulator (21mm)
Old 07-22-2003, 08:29 PM
CHRISPY's Avatar
awesome thanks!!
So this is what I need right?
Suspension
Quick Reply: GM part #s for 98-02 1LE front and rear swaybars?
