Car is hard to start, then sputters, then runs fine... any ideas
Old 03-12-2008, 11:16 PM
98RedBird's Avatar
Default Car is hard to start, then sputters, then runs fine... any ideas
I'm trying to help a buddy out with his car and I'm kind of stumped. Here's what happens: On a cold start it cranks longer than it should need to and then sputters to life. Sometimes you need to feather the throttle to keep it running but sometimes it's fine. Upon startup I notice a strong gas smell as well as smoke coming from the tailpipe, more than likely unburned fuel. Once it gets past the sputtering and choking which last only for about 15 to 30 seconds it calms down and runs just fine. Every once in a while all of the sputtering will cause an Check Engine Soon light to turn on for misfire, then it goes out after a few key cycles. Once the car is warmed up it will start right up as soon as you hit the key, but if you let it sit and cool off for an extended period of time it will be hard starting again. Any of you guys have any ideas on what this sounds like? Cold or hot weather doesn't affect this condition either way. It acts the same regardless of the temp outside. Funny enough cold weather might help it slightly.
Any help would be great. It's his DD. Thanks guys.
Old 03-12-2008, 11:24 PM
98 T/A raptor's Avatar
fuel pump mine did that before it went out, or just a tune up.
Old 03-12-2008, 11:34 PM
98RedBird's Avatar
But if it was a fuel pump wouldn't it have issues while running too? It should have just as hard a time maintaining fuel pressure as getting it there under cranking conditions, right? Same with a tune-up. The car runs perfectly fine once started.
Old 03-12-2008, 11:35 PM
SchultzLT1's Avatar
plugs I would say
Old 03-13-2008, 12:30 AM
98RedBird's Avatar
Checked the plugs out. They all look great.
Old 03-13-2008, 07:31 AM
BadGTho's Avatar
not plugs. basically the car is stuck in cold idle or warm idle loop when it isn;t supposed to be. check for codes.
sometimes it's either and air or coolant temp sensor that causes this. sometimes it's just a dirty throttle.
Old 03-13-2008, 10:14 AM
SparkyJJO's Avatar
My V6 does something similar, but without any SES light and nothing odd out the tailpipe. Was told it could be fuel pressure drops off when the car sits since it acts like there isn't any gas.
Old 03-13-2008, 10:40 AM
JHL88's Avatar
i would say ignition coil but that wouldnt cause unburned fuel to go out the back end. id recommend a full tune-up
Old 03-13-2008, 11:16 AM
BadGTho's Avatar
umm ok .. one more time.
you're having a start up issue related to the fact that the computer does not know if the car is hot or cold... clean the throttlebody and mass air..... check for codes.
you could have a bad intake air temp sensor.
ignition coil> c-mon guys
Old 03-13-2008, 03:13 PM
98RedBird's Avatar
Okay thank man. I'll check into it. It makes sense. No codes by the way.
Old 03-13-2008, 10:21 PM
01ssreda4's Avatar
dont think its a tune up problem. obviously the computer is dumping the wrong mixture until it figures out what the hell is going on.
Old 03-13-2008, 10:30 PM
98RedBird's Avatar
That's what I keep thinking but I'm just not sure why it's confused and there's no codes so I'm not sure where to look
Old 03-14-2008, 12:30 AM
KENS_SS_4's Avatar
Leaky fuel injector maybe, lets the rail dain into manifold while sitting then the you try to start in an already flooded condition. Try pressing the gas peddle to the floor before you put the key in and hold it there. Then start this is the normal start for flooded engine. Maybe a good injector cleaning will fix it. Good luck
Old 03-14-2008, 01:08 AM
Rushin's Avatar
Strong gas smell, sputtering, and smoke out the tail pipe. Yep, you've got a case of motorfloodititis. Injector driver in the PCM is causing the injectors to be stuck open. What BadGTho said is right. Clean the MAF and check O2 sensors.
Old 03-14-2008, 07:34 AM
BadGTho's Avatar
dude. seriously.
please explain how that's even remotely possoible as a cause.
Old 03-14-2008, 07:22 PM
lonala's Avatar
could it be the crank senser
Old 03-15-2008, 03:30 AM
KENS_SS_4's Avatar
dude. seriously.
A fuel injector is a normally closed electricly opened valve. They can leak in there normally closed condition Dude.
Old 03-15-2008, 03:33 AM
Rushin's Avatar
Read what you just said.
Old 03-20-2008, 05:32 AM
KENS_SS_4's Avatar
Another one
Leak is a "malfunctioning condition" in which something passes that is supposed to be controled not to pass.
Rushin, at least you did'nt say Dude.
Old 04-07-2011, 06:58 PM
Mfran4776's Avatar
98Redbird
Did you ever solve this problem and if so what was the fix? I've have the exact same thing happening to me now. Thanks for any help you can give me.
Quick Reply: Car is hard to start, then sputters, then runs fine... any ideas
