external wastegate vacuum line hookup
Old 03-07-2008, 08:20 AM
lt170chevelle's Avatar
Default external wastegate vacuum line hookup
where do i hook up my vac lines to my external wastegate top or bottom? bottom only?top just a vent?
Old 03-07-2008, 08:26 AM
punishment's Avatar
This link should answer about any wastegate installation question:
http://www.tialmedia.com/documents/w..._wginstall.pdf
Old 03-07-2008, 08:28 AM
LS1Tech Sponsor
Superman09's Avatar
hook up to the side for reference, top for control. So if your just running off of the WG spring for boost, only connect to the side and vent the top. If your running a boost controller, you hook the controller to the top. Hope this helps. I'm referencing off of a Tial 38mm.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-07-2008, 08:37 AM
deadmanTA's Avatar
My tail 44 instructions say only side port, vent top. Manual BC hooks inline of that and for EBC use manufacture's recomendation for hook-up.
Old 03-07-2008, 12:26 PM
ok thanks guys this will help allot
Quick Reply: external wastegate vacuum line hookup
