working on a 67 nova wagon twin turbo combo
Old 03-02-2008, 08:28 PM
single digit dreamer
parish8's Avatar
Default working on a 67 nova wagon twin turbo combo
we picked up roller for pretty cheap and have been working on a 6.0/4l80e/twin set up. probably wont be running for a few more months but things are coming along.
it is starting to look like something. got the motor and tranny mounts made, motor is bolted in. got the cooling system done. the accesory system is done. the headers are mostly done. going to get dimentions for the twin throttle body t next weekend and get it on the way. got the drain fittings welded on the pan. got the charge pipe stuff ordered up, working on some coil mounts. it is going to be a staged duel fuel 87octane/meth with no intercooler. http://www.neufamily.org/images/67no...ry/index_3.htm
Old 03-02-2008, 08:52 PM
71chevellels1's Avatar
Wow, this set up looks really nice.
Old 03-02-2008, 11:21 PM
X88&94GT's Avatar
wow, very nice, always love seeing some old metal built.
Old 03-02-2008, 11:23 PM
babydeuce's Avatar
In a stock clip car, I Fing love it!!!
Jack
Old 03-05-2008, 11:50 AM
MeanYellowZ's Avatar
Awesome....as usual with your stuff......Do you tune for other people or just your own stuff??
Old 03-05-2008, 01:21 PM
Old Geezer's Avatar
Blowing all that hot air from the rad, into the air cleaners, makes me wonder how much boost will be useable on 87, and no I/C.
Other than that, NICE!!
Old 03-05-2008, 04:33 PM
parish8's Avatar
we wont be runing much if any boost on 87. it will be a staged duel fuel meaning as the boost comes on it will switch over to meth. by the time it gets to 8psi or so it will be 100% meth.
Old 05-29-2008, 05:20 PM
ForcedInduction's Avatar
Default where did the 6.0l come from
The 6.0l motor looks like a bow auto salvage unit out of NH. They have been the cheapest so far for truck LS motors we have found. We are using one in our 99 ls turbo mustng build at giffinsperformance.com We also used a 5.3 in my 89 gmc w/ a mpt70 and a th400 w/brake. We would also like to put our spare 5.3l mpt70 into our datsun 610 and run it agaist your fairmont on pinks. Both cars would be running megasquirt units. Later. G
Old 05-29-2008, 06:09 PM
Skele4door's Avatar
Would you mind sharing with us what tubing you used for your log manis? It looks like thick walled stainless, but I'm just curious. They look nice and tight to the block and would probably work great for people that want AC so they can't use flipped truck manis.
Old 05-29-2008, 07:52 PM
parish8's Avatar
we get our motors at a local junk yard. 5.3's are $450, 6.0's are $800.
the tubing is scheduel 10 stainless. pretty cheap. the little 90's are $7, the big 90 was something like $12. each header has about $150 worth of material not counting the waste gate flange.
Old 05-29-2008, 07:55 PM
parish8's Avatar
haven't done much to the car lately. been working on a kick *** garage. here is a pic from the last time we touched it.
Old 05-29-2008, 08:08 PM
Goober79's Avatar
Wow. I can see magazine time.
Old 05-29-2008, 11:28 PM
sawzall wielding director
G-Body's Avatar
How does that work? I`m guessing its a custom setup, but is it 2 complete fuel systems with separate rails and injectors? Or a common rail/injectors and just different tanks and pumps with check valves. Either way it sounds pretty trick.
What made you decide on methanol over E85? seems like a lot of the boosted applications are running e85 now because of the availability.
Old 05-30-2008, 12:51 AM
chevyguy7802's Avatar
Looking great man! Im lookin forward to see what this puppy does!
Old 05-30-2008, 07:32 AM
stealth71's Avatar
Wow. Sweet project. Fab work looks good. What's up with the extra injectors near the throttle body?
I was like damn this is one badass car. Then I saw it's Parish. What else would you expect?
Old 05-30-2008, 08:36 AM
Skele4door's Avatar
Thanks for the info man. I never thought about using pipe for a turbo exhaust mani, but I guess the added thickness would make it stand up to heat cycles much better. One more quick questions if you don't mind. I haven't messed with pipe before, are flares/transitions like you used from the rear primaries into the log an off the shelf part? I doubt you'd be able to do that with an tubing expander.
Old 05-30-2008, 02:45 PM
G-Body's Avatar
The fittings and transitions are off the shelf parts. They are normally used by boilermakers/pipefitters. The steel ones are pretty easy to find, but stainless like parish used is also available. http://www.mcmaster.com/ has them but their prices are a LOT higher than parish paid
Old 05-30-2008, 10:00 PM
parish8's Avatar
it will be 2 complete fuel systems. one with pump gas and 4 injectors into the elbow and one with meth into 8 intake mounted injectors.
we are not 100% sure on what fuel we will be using but we are not going to have an intercooler so it seems like meth would be the way to go.
i get my stuff at mcmaster. the little elbows are now listed at $8 and the bigger ones listed at $18. still not a bad deal.
Old 05-30-2008, 10:26 PM
G-Body's Avatar
I must have been looking at larger diameter fittings. I was looking at more like 3" and 4" but then after I logged off it hit me that the manifold was probably smaller. Maybe 3" collector and 1.75 or 2" primaries?
That elbow looks wicked with the two TB`s.
Old 05-31-2008, 12:33 AM
parish8's Avatar
i used 1.5" primarys and 2.5" logs. when you use pipe like that the actual dimentions of the inside are often bigger than the "trade" size. you have to look at the specs. the 1.5" sch 10 are more like 1 5/8" inside so perfect for the ls1 exhaust port. i like how these headers turned out.
Quick Reply: working on a 67 nova wagon twin turbo combo
