4l60e front bushing replacement?
Old 02-25-2008, 10:04 PM
yeary03SS's Avatar
Default 4l60e front bushing replacement?
Ok, did a search with no luck, i'll admit i'm no tranny expert. Anyway, got the front seal out, is there a special tool needed for the front pump bushing removal/install? Any tips/help is much appreciated.
Kyle
Old 02-26-2008, 08:10 AM
built408's Avatar
Any bushing, or bearing race driver will drive it out... Install it the same way it came out... Is the trans torn apart or are you trying to replace it still together????
Old 02-26-2008, 08:25 AM
LS1Tech Sponsor
performabuilt's Avatar
The pump must be removed and dissassembled to replace the bushing as the bushing must be installed from the back side of the pump, You will need a bushing driver set and a way to align the pump
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-26-2008, 05:21 PM
yeary03SS's Avatar
Thanks guys, the pump is still together, but it looks like i'll be taking this to a shop who has the right tools.
Quick Reply: 4l60e front bushing replacement?
