5.3 wiring harness Wiring diagrams here!!!
Old 02-23-2008, 02:05 PM
91parkave's Avatar
Default 5.3 wiring harness Wiring diagrams here!!!
Thanks to my man Mark west for hooking this up for me these are fuseblock and PCM and other essential wiring diagrams
CHIVOBLING (07-14-2023)
Old 02-23-2008, 02:13 PM
91parkave's Avatar
The following 2 users liked this post by 91parkave:
CHIVOBLING (07-14-2023), ptaylo5784 (07-11-2023)
Old 02-23-2008, 07:04 PM
brentg454's Avatar
Thumbs up Nice Info!
Good stuff...Thanks for posting up!
Old 02-23-2008, 07:21 PM
SheldonZ28's Avatar
Sweet Jesus. Your a life saver!
Old 02-23-2008, 07:43 PM
orangefun's Avatar
what is the differance between pcm1 and pcm2
Old 02-23-2008, 10:04 PM
orangefun's Avatar
which one is the blue one and which is the red
Old 02-23-2008, 11:12 PM
91parkave's Avatar
C1 should be blue C2 should be red verify by comparing the wire colors to the proper pin outs.
Old 02-24-2008, 02:44 AM
fast400's Avatar
I smell a sticky!
What year are the diagrams?
Old 02-24-2008, 05:30 AM
eagleuh1's Avatar
Default What year
I bet they're 2005!!
Old 02-24-2008, 07:31 AM
Gm-LSX's Avatar
Model of 5.3? There are more than a half dozend of them with at least 3 differnt ECM's plus E38 ECM's (taken from the 6.2) with support for the 6L80/6L90.
Old 02-24-2008, 09:03 AM
50adrod's Avatar
they are from a 2005/2006 Tahoe with a 4L60E 2WD
Old 02-24-2008, 03:25 PM
98blackSS's Avatar
Yep. Some '05 5.3L motors use the E40 ECM like the one I'm installing in my Jeep now.
Old 02-25-2008, 01:59 PM
orangefun's Avatar
thanks i will be going throuh the wiring this weekend. hopfully it will start
Old 02-03-2010, 07:47 PM
MillsMotorvation's Avatar
This is as close as i have gotten to finding the (PIN OUT) for the computer to this engine i just got! I have a LQ4 6.0 liter out of a truck(2002), any one can give me a link to it. Ive been looking for hours, and all anyone says is do a search, i did and cant find it HHHHEEEELLLPPPPP!!!!! I just want to see if i can use the stock harness, and comptuer i got with the engine.
Old 02-04-2010, 01:00 AM
code4's Avatar
I think i used this one for my 2000 pcm. I didn't even know what year is was until i down loaded the tune. Yours should be close, just use common sense. Many of the wires are easy to figure out on your own by the plugs. Cam, crank, tps, iac plugs etc. If your color does not match then rethink it.
I don't use all the plugs & fuse block. I cut all that off & wire up my own set up. 15 amp each +12v for bank one & two coils, 15 amp each +12v for bank one & two injectors, a few other power & grounds & it will run.
http://www.lt1swap.com/99-02_vortec_pcm.htm
Old 04-09-2011, 02:12 PM
richard_lyew's Avatar
hi all, does anybody have the PCM/ECU/ECM pinout for the 1999 GMC Yukon Denali V8?
Old 04-06-2014, 10:18 PM
axelfoxx's Avatar
i need the 2001 schematic for a silverado 1500 :C all the ones i have found so far come nowhere close to matching my c1 layout
Old 04-20-2014, 01:16 AM
91parkave's Avatar
see attached
File Type: pdf
Old 06-20-2015, 10:41 PM
John McPherson's Avatar
Ok it is now 2015 and this information is still useful :-)
have had the 5.3 in a '87 T-Top LS Monte Carlo and just getting to the A/C - it is important to run the A/C through the PCM to avoid over pressure and have A/C compressor clutch off at WOT. Thanks to all who posted here. going to upload some additional content because the wire descriptions are the same, but the pin location is different from 2000 and 2007 - 2008 to 2012 then again 2013 to 2017. LT1swap has a lot of good information there. People who buy ready made harnesses really miss out because when something goes wrong the intimate knowledge of how it all works is missing and then they are stuck. Kudos to all posting here.
Last edited by John McPherson; 06-20-2015 at 10:44 PM. Reason: clarification added
Old 06-21-2015, 11:52 PM
tta656's Avatar
Default awesome
Quick Reply: 5.3 wiring harness Wiring diagrams here!!!
