Tricks on tightening crank bolt
Old 02-07-2008, 09:09 AM
04gtod's Avatar
Default Tricks on tightening crank bolt
Installing a ASP UD pulley in a automatic car. I've used the Summit tool to hold the crank pulley while tightening bolt in the past. That tool won't work with the ASP pulley. Does anyone have a trick to tightening the bolt with the aftermarket pulley.
Old 02-07-2008, 09:57 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Search for username 618HAWK
He makes a pulley install tool that makes it a breeze
Old 02-07-2008, 10:10 AM
04gtod's Avatar
What I an asking is in a auto car the torque converter spins freely so how do you hold the crankshaft while tightening the bolt?
Old 02-07-2008, 10:27 AM
ryansm1's Avatar
Drop the starter and use a big screwdriver/pry bar (or the GM tool) to hold the flexplate in place.
Old 02-07-2008, 10:33 AM
m6speed's Avatar
or use your old belt and put the waterpump back on and rig it so the belt keeps it from spinning.
Old 02-07-2008, 12:03 PM
massls1guy's Avatar
I don't think that will work
Old 02-07-2008, 12:25 PM
vettenuts's Avatar
Buy the correct tool to engage the teeth in the flywheel. Its a few bucks up front and prevents possible problems. Problems caused by using incorrect tools or jury rigged methods tend to cost more in the end.
Old 02-07-2008, 02:05 PM
HMFDZ28's Avatar
I have the flywheel tool from GM....why bust a knukle
Old 02-07-2008, 03:38 PM
larrygto's Avatar
+1 I got my tool for $29 on ebay.
Old 02-07-2008, 04:24 PM
DONAIMIAN's Avatar
I have the flywheel too also. GM wont be changing anything for a while so im sure it will be usable on future GM V8's.
Old 02-07-2008, 04:25 PM
Hell'sChariot's Avatar
I just used a chain, and wrapped it around the sway bar. I has always worked great.
Old 02-07-2008, 06:30 PM
huggybear17's Avatar
1/2 impact will work LOL!!!
i recomend the gm flywheel holdin tool makes it a breeze
Old 02-07-2008, 06:45 PM
blkbird's Avatar
I had the fortune of being able to use a lift. I made the rear tires touch the ground while in fifth gear and used a 2ft breaker bar. Good luck.
Old 02-07-2008, 08:21 PM
1BADAIR's Avatar
doesn't work with an auto
Old 02-07-2008, 08:26 PM
99Hawk262's Avatar
Big impact wrench and loctite here. Not saying it's the correct method, but it's not coming back out either.
Old 02-08-2008, 03:18 PM
GuitsBoy's Avatar
use the threaded rod method. Not fun drilling out and helicoiling the crank. The screwdriver trick works, but if you can get the tool, even better.
Old 02-08-2008, 05:43 PM
eallanboggs's Avatar
Chain wrench in the plumbing dept at Sears.
Old 02-08-2008, 06:05 PM
blkbird's Avatar
Youre a brave man......
Old 02-08-2008, 06:23 PM
99Hawk262's Avatar
^^I should add that I made certain it was well seated and plenty of threads started before I cranked down on it. I heated my ASP pulley in the oven and it slid on like butter. Once everything was situated, I cranked her down and then let the impact wrench hit on it for 30 seconds or so. It'll come back out if I ever need it to, but not on it's own.
Quick Reply: Tricks on tightening crank bolt
