whats the best coolant system stop leak
Old 02-05-2008, 12:01 AM
slowscott's Avatar
Default whats the best coolant system stop leak
My daily seems to be using some coolant what is the best coolant system stop leak?
thanks
Old 02-05-2008, 01:21 AM
transAm-98's Avatar
Ive always been told to stay away from any "stop leak" type additive for oil or coolant. First thing i would do is try to see if you can trace the problem before possibly gunking up your radiator.
Old 02-05-2008, 01:22 AM
transAm-98's Avatar
Just realized you said it's your daily. I guess if it's your beater than you could start with whatever is cheapest
Old 02-05-2008, 04:38 AM
venomhp's Avatar
when you run stuff that is purposely trying to gunk up (patch) the leak, its going to gunk up and give you problems in the future...do it right the first time, find out where its leaking...
Old 02-05-2008, 12:21 PM
chromeplated500's Avatar
yeah... I used some cheap stuff before on my 91 chevy w/240,000miles... .but it would be better to fix the problem... so your not stranded on the sidee of the road.
Old 02-05-2008, 01:04 PM
MagnaTransAm0098's Avatar
whynns or B&G dont use any of that powder ****, if it isnt leaking bad just starting these 2 will be fine, make sure its for the right color antifreeze, you can get the stop leak for both colors...
Old 02-05-2008, 10:52 PM
Formula413's Avatar
I tried Bars Leak when my DD had a leaking radiator (where the tank met the core). Didn't work, just ended up replacing the radiator. Some people say stuff like that can clog your heater core, might not be worth the risk.
Old 02-05-2008, 11:42 PM
KENS_SS_4's Avatar
Do it right and fix the problem.
Old 02-07-2008, 10:30 AM
loser98's Avatar
correction its wynns not whynns, read the directions, its a fluid additive so its not going to hurt your core or pump or anything eles, used it in a lot of cars over a lot of years, but plan in the near future to get it fixed the right way.
Old 02-07-2008, 11:00 AM
qwk93ta's Avatar
GM has a product called seal tabs that they use for warranty work -- leaks. You can pick it up at any GM dealership for about $5.
Old 02-07-2008, 07:34 PM
slowscott's Avatar
My coolant looks like it has oil in it too. Is it really oil or could it be the result of the previous owner using stop leak?
Old 02-09-2008, 04:54 PM
slowscott's Avatar
Doesn't seem to leak on the ground and the oil on the dipstick does not appear to be milky
thanks
Old 02-10-2008, 06:31 AM
loser98's Avatar
do a pressure test...and test the cap maybe your loosing it when your driving it cause it has a bad cap...
Old 02-10-2008, 10:32 PM
NightRider2000's Avatar
Don't do the stop leak! That **** is so bad and gets in all your ****. If you like your car pressure test it first. If your an auto check your trans fluid.
Old 02-11-2008, 03:22 PM
slowscott's Avatar
What would the trans fluid have to do with the coolant?
Old 02-11-2008, 05:01 PM
Formula413's Avatar
Both run through the radiator, in seperate passages of course. The radiator could have an internal leak letting the two mix.
Old 02-12-2008, 03:05 PM
slowscott's Avatar
Well it definitely is burning the coolant, I can smell it at startup. My daily is an impala with the 3400 v6 that I found out is notorious for leaking lower intake manifold gaskets. Is there a way to narrow down if its the intake manifold gasket or if its a head gasket instead?
Quick Reply: whats the best coolant system stop leak
