What spark plugs to use in 402 LS2 stroker
Old 01-27-2008, 08:34 PM
Doc99SS's Avatar
Default What spark plugs to use in 402 LS2 stroker
Are the plugs the same depth as the LS1 plugs? And what would be a good plug for my 402 LS2 engine? Please see details in my sig. The CR should be about 11.0:1...
Old 01-27-2008, 11:28 PM
89Formulaws6's Avatar
i was told tr6's for my 408 and my c/r is more then that
Old 01-28-2008, 12:44 PM
transAm-98's Avatar
i'm running TR6's, my compression is around 11.8,
Old 01-28-2008, 01:24 PM
ChrisS@sdpc's Avatar
We have had good experience with the NGK's. Not for sure if a colder plug is needed in your setup.
Old 01-29-2008, 05:47 PM
rpmauto's Avatar
i ran the tr6 in my ls1 with the juice. no problem. transam98 and 89formulaws6 are you guys running pump gas with more that 11:1 compression?? just curious i am soon to order the heads for my 402 and was thinking of going 11:0 or 11:5 to 1
Old 01-29-2008, 06:58 PM
Order 66's Avatar
TR6 if you run stocker style cylinder heads. If you run ET or another that new cast check with the manufacturer because they use a different plug.
Old 01-29-2008, 08:30 PM
silver01z06's Avatar
11.0 is fine for pump gas. My engine is not that high but several friends are 11.0 or higher and have 0 issues with that compression and pump gas.
Old 01-29-2008, 11:21 PM
BadLtBlu99TA's Avatar
Question how to figure out the compression ratio ?
how do you calculate the compression ratio for an engine with heads ?
Old 01-30-2008, 12:12 AM
transAm-98's Avatar
I'm running 11.8 CR on shitty California 91 octane. with the right cam and the right tune it's not a problem
Old 01-30-2008, 05:26 PM
Fast99408's Avatar
in my 408 im running tr6's there the best
Old 01-30-2008, 08:17 PM
LS1Tech Sponsor
Slowhawk's Avatar
TR-6 gapped to .045 -.050
Old 02-02-2008, 09:42 AM
12 Second Truck Club
supersub's Avatar
Tr 55,tr-6 .045-.055 depending on comp ratio's and coldness requirements
Quick Reply: What spark plugs to use in 402 LS2 stroker
