1000hp radiator for a street car?
Old 01-22-2008, 07:17 PM
C Murda's Avatar
Default 1000hp radiator for a street car?
what radiator is best for 1000hp? i dont want to cut away at my radiator support unless absolutely necessary but was planning on tilting whatever radiator i may get upwards as much as i can. just need it to fit in the stock location and if possible find a way to reuse my stock cooling fans as i read they are very good for cooling.
Old 01-22-2008, 07:20 PM
Jimmy P's Avatar
A bunch of cars are making big power with the stock radiators. I upgraded mine to a BeCool aluminum radiator because I was having cooling issues.
Old 01-22-2008, 08:04 PM
C Murda's Avatar
only reason why im really curios is as i look into radiators they have horse power ratings so that brings up the concern of the factory unit supporting a ton more power than stock? im looking at 850RWHP pump gas and street driven. also it will be a turbo 427 motor...
Old 01-22-2008, 08:15 PM
Shawn @ VA Speed's Avatar
We use ron davis aluminum radiators with great success in cars like that
Old 01-22-2008, 08:18 PM
LS1Tech Sponsor
Slowhawk's Avatar
A stock radiator will work if there is no AC.Of course tilting the radiator too much will screw up the cooling alot. I see no problem cutting the support though.
Old 01-22-2008, 09:26 PM
MotleyDrew's Avatar
I use a Dewitts Rad. Works Great even with a huge intercooler mounted directly in front of it !
Old 01-22-2008, 09:44 PM
bboyferal's Avatar
750hp here... Stock radiator in the stock location has been fine for over a year... Sees 17 psi on a regular basis and been in some traffic... Yes I have AC. This is Miami.
Old 01-22-2008, 10:05 PM
Websy21's Avatar
Bought the car with an upgraded one, I think it was the evans pump and rad. Basically a LT1 I was todl which is bigger and suppose to be better. I'd have to look I got the receipt somewhere.
Old 01-22-2008, 10:14 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
A few of my friends have GRIFFIN or BE-COOL rads. Not in F-Body's though.
Old 01-23-2008, 09:05 AM
C Murda's Avatar
well thanks for all the input...i guess ill try my stock one first. as for what Slowhawk said about screwing up the cooling by tilting it up is this only cause of how the airflows through it when its tilted up more? i do have plans for a large FMIC and ofcourse removing my AC as it doesnt even work anymore anyways...
Old 01-23-2008, 09:09 AM
bboyferal's Avatar
What Slowhawk says is true... All the people that bitch about the stock radiator not cooling have, more often than not, tilted it, removed the airdam, or have a radiator facing upright with a FMIC blocking the front... Of course it will overheat or be taxed this way...
Old 01-27-2008, 12:50 AM
barnat's Avatar
Default Be Cool#1
Same here bud ,Went with the BE COOL racing kit,Extra thick rad as compared to the street one .Also got the 2 high output fans with shroud and wireing kit, Like $1300 somthing from SUMMIT RACING. Took 2 days, drop shipped from BE COOL ,I'm touching it as we speak LOL !!!!
Old 01-27-2008, 01:10 AM
Super Moderator
Reckless's Avatar
Two of the best are Ron Davis and Fluidyne....have had mixed results with the Be-Cool stuff. I really serious radiator will cost you $600 - $900
Old 01-27-2008, 01:21 AM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
I just went with a PRC and it is very nice stuff.And priced right!!!
Old 01-27-2008, 02:16 AM
Websy21's Avatar
Thats one of the coolest avatars I've seen, lol
Is that your ride?
Old 01-27-2008, 06:20 AM
BoostnTBSS's Avatar
I second Ron davis they make great rads. and they look killer too..
Old 01-27-2008, 08:27 AM
SUPERBOOST's Avatar
What about the griffin,anyone using it with good results or not?
Old 01-27-2008, 09:30 AM
1INSANEGTO's Avatar
1300? Complete 600 to 700 for a radaitor? If you guys are interested PM me what you want.
I designed mine for 1000rwhp@++++
Pics are located at https://ls1tech.com/forums/pontiac-gto-2004-2006/851211-custom-radiator.html
I can get them for alotttt cheaper then $1300.00 complete with radiator, shroud, dual Spal fans to top it off there built to your specs.
Old 01-27-2008, 09:52 AM
HUNTER02SS's Avatar
I bought a universal griffin radiator from summit racing for around $2-300 dollar's. 3 core and it's the same dimensions as stock.
Old 01-27-2008, 12:16 PM
platinum1's Avatar
ron davis going in my car and they kick ***!
Quick Reply: 1000hp radiator for a street car?
