Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
{HELP} how to install floor pans in a 69 camaro????
Old 01-22-2008, 05:13 PM
johnster's Avatar
Default {HELP} how to install floor pans in a 69 camaro????
hey guys, need some help,, the car is a hard top and a friend of mine is about to put new floor pans in it. What would be the best way to go about doing this? Should he just cut out the old floor pans and put in the new or should he try and brace the body before cutting? thanks john
Old 01-22-2008, 07:22 PM
morrisclassic's Avatar
Default Floorpans
Cut and replace them one at a time. If you are replacing the each entire floorpan I would brace it before cutting the old one out.I only replace the amount that is needed. Cut the replacement about 1/8" short and butt weld in, radius the corners because if you don't it will jam up and not fit properly. Weld a smallamount then move to the other side and weld a little ,try not to distort the panel or the cars floorpan. Billy
Old 01-23-2008, 11:33 AM
Elite_Hot_Rod's Avatar
This is the best 1st gen web site by far, go here and ask in the body shop forum. http://www.camaros.net/forums/
Old 01-23-2008, 10:00 PM
johnster's Avatar
thanks guys
Quick Reply: {HELP} how to install floor pans in a 69 camaro????
