Why does my starter keep going OUT???
Old 01-14-2008, 03:55 PM
Big_Time_SS's Avatar
Angry Why does my starter keep going OUT???
Hello,
So here is the deal, I have a 94 Z with a starter problem.
When I bought the car with 128k mi. on it, It had signs of the starter going bad but it turned on everytime, until about three weeks ago. It gave up
So I went down to AutoZone got a replacement, and have had nothing but problems with it, replaced it five time already...
I do not know if its the starter from autozone or something else from the car..
Should I just get my money back and get one from the dealer???
Thanks for any Info..
Old 01-14-2008, 04:07 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
What are the symptoms? Are they testing the starters you're returning and confirming that they're bad? Unless you're extremely unlucky, or they got a bad batch of starters at one time, I would suspect something other than the starters.
Old 01-14-2008, 04:32 PM
Yes they are testing the starters and confirming that they are bad..
I really dont know where else to look. The car has Headers and I have wrapped the starter with a heat jacket that I bought from autozone.
The fourth one I got was bad from the counter, but all the others have started just fine they last about three or four starts then three of them that I pu on dont stop spinning I have to go in and disconnect the battery.
Old 01-14-2008, 04:40 PM
Hot94Z28's Avatar
Since You have headers I would suggest getting a Corvette starter. People call it a LT4 starter it is smaller so it will be away from the headers and makes it easier to change spark plugs.
Old 01-14-2008, 05:42 PM
letsrun97z's Avatar
i bought a new one couple mos ago 210$ works great (autozone)
Old 01-14-2008, 05:53 PM
BizZzatch350's Avatar
Thats really weird, check the wiring and make sure the batter has full voltage when you go to install the starter. I have seen notes that say if you install a starter with low battery voltage it can hurt the, dont know how, but I have seen that on several web sites that sell starters
Old 01-14-2008, 05:59 PM
I dont think anything else is bad, cause everything else was fine before the other starter went out. Maybe im just getting bad remanu. starters from autozone maybe i need to try the dealer one for 300 dollars.
Old 01-14-2008, 06:09 PM
infinitebird's Avatar
apparently some people have had good luck with the ebay ones. they are much cheaper.
Old 01-14-2008, 08:19 PM
buffman's Avatar
I've had no problems at all with the LT1 spec Corvette Starter from Autozone. It's only $120 (regional pricing, it's more in some places) + the core.
Matt
Old 01-14-2008, 09:54 PM
RickyMartinZ28's Avatar
Should I heat wrap my Starter on my LT1? I didn't think it was close enough to worry about.
-Rick
Old 01-14-2008, 10:30 PM
95 bright teal's Avatar
My freind had bad luck with autozone starters, they have the warranty but who wants to take them back all the time.
I went to napa a year ago and havent had problems
Old 01-14-2008, 10:38 PM
Doc Mitch's Avatar
is your intake leaking? when i replaced mine, it was covered in old oil from that, and im sure that wasnt helping it last any longer.
Old 01-15-2008, 01:28 AM
gatorhead's Avatar
I can shed a little light on the situation.
First when they give you a starter have them check it before ever leaving.
Second if there is too low a volatge to ANY motor it will cause it to prematurely fail. However 3-4 starts is very over dramatic regardless of the voltage.
Check to make sure your wiring is correct, and that the ground is secured, it attaches to the side of the block and it is needed!
Old 01-15-2008, 01:35 AM
Formula350's Avatar
Is it shimmed wrong and making it work harder somehow?
Old 01-15-2008, 05:24 PM
buffman's Avatar
^^ Most of the time I've seen no shimming needed for LT1 motors, but on occassion it is necessary. I've only read about one Duralast LT1 Vette Spec'd starter failure so far, and the guy wasn't sure why it went to hell.
Old 01-15-2008, 07:30 PM
BTC
BTC's Avatar
I got my car out of long term storage a little over a year ago and the starter went bad while we were trying to get it running. I got a replacement at Autozone. It's still working, but my car has been on jack stands for about a year and isn't being started on a daily basis.
Old 01-19-2008, 07:43 AM
95ZRagtop6M's Avatar
Mine was hard on starters also. I think the combo of LTs and high compression was causing the problem. I bought a high torque starter from NAPA and it works much better. It wasn't cheap though ...
Old 01-19-2008, 02:04 PM
socal's Avatar
im running an AZ starter on my truck no problems yet
Quick Reply: Why does my starter keep going OUT???
