Throttle body size
Old 11-18-2007, 08:37 PM
NetrixTardis's Avatar
Default Throttle body size
so, the 2002's T/A 's had the LS6 intakes. i've read somewhere (tho i can't find it anymore) that the TB size is a 70mm, and the LS6 intake can take up to 75mm... anyone have info to confirm/deny this?
Old 11-18-2007, 09:32 PM
mikenews's Avatar
Factory tb is about 72mm. We remove the restrictive .0120" ridge and just about achieve 75mm total opening when we port them. The actual opening is larger but not sure how much. Anyone???
Old 11-18-2007, 10:01 PM
hmm. so, whats the largest size that the LS6 intake will bolt up with?
Old 11-19-2007, 11:21 AM
mikenews's Avatar
I believe 90mm. I would just have your factory ported and polished. Save your $ for other mods. Factory TB's modified work very well!
Old 11-19-2007, 01:01 PM
5.0stang's Avatar
So what is the official throttle body size?
Anyone got a picture?
Old 11-19-2007, 03:12 PM
Restricted User
Smokin87TA's Avatar
After porting a stock tb is a true 75mm all the way through. From factory they are right around 71.5mm. An ls6 intake opening is 78mm so with anything larger than that you would have to use a reducer, this making it pointless going larger since the air has to restrict to get into the intake. Ported stocker and ls6 is a proven combo, next is to step up to a 90/90.
Old 11-19-2007, 04:25 PM
5.0stang's Avatar
So I am assuming the small part of the throttle body is on the firewall side, or on the radiator side?
What horsepower are the ported 75mm throttle bodies good too?
Old 11-20-2007, 12:25 AM
mypoorLS1's Avatar
If you take off the TB, you will see a lip that goes all the way around. It is very noticable. Take the TB apart, grind this lip off and smooth it out. It's easy and should pick you up 5 to 10 rwhp depending on your current mods.
Old 11-20-2007, 07:23 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Best bud put on a FAST 78mm TB, works fine. He kinda regrets since he cant use it unless he stayed with a 78mm FAST intake, he wants a 90mm, but im sure he can sell it.
Old 11-20-2007, 11:39 AM
5.0stang's Avatar
Has anyone flowed a stock and ported throttle body?
So is the official size 71.5mm?
Old 11-20-2007, 06:36 PM
mikenews's Avatar
Do a search for that issue. Bo white polishes and ports them. Gains of 5-8 rwhp on dyno is not uncommon. I think his website is portsculptors.com
Old 11-20-2007, 09:01 PM
5.0stang's Avatar
I tried
Old 11-26-2007, 06:40 PM
barnat's Avatar
Default Tb
Look under ls1 throttle bodys,!!! there is like 3 or 4 companys that cnc do them!!
Old 11-26-2007, 07:46 PM
74chevystepside's Avatar
Default Newbie here
Ok let me ge this right. In order to have a 90 mm throttle body you have to have a 90mm intake, correct?
Old 11-27-2007, 12:43 PM
5.0stang's Avatar
So what is the official size of a stock ls1 throttle body?
Old 11-27-2007, 12:48 PM
MASS seller approved
smok'nZ's Avatar
71.5 read the thread
Old 11-30-2007, 04:24 PM
5.0stang's Avatar
Um, I did.
I just got answers that said "about" and they varied.
So I was wanting to know the official size, confirmed.
Old 11-30-2007, 04:33 PM
3rdgentug's Avatar
ive always read/heard 71.5 refered to as a 72mm
i used ported 78mm on my intake for years, worked great.
Quick Reply: Throttle body size
