ARP 1/2? && 3/8" head stud torque specs
Old 09-07-2007, 06:26 PM
7 Second Club
Phil99vette's Avatar
Default ARP 1/2? && 3/8" head stud torque specs
ARP says:
factory 8mm studs go to 22ft/lbs
11mm: 70ft/lbs
The chart look like:
1/2" x 20 = 107ft/lbs
3/8" x 24 = 44ft/lbs
If memory serves me correctly main studs are 60 inside/50 outside for aluminum block, iron the same?
Old 09-07-2007, 06:30 PM
3.4camaro's Avatar
which one do you want specs on? Main studs or head studs?
Old 09-07-2007, 09:13 PM
7 Second Club
1/2" head and 3/8" head studs.
Old 09-08-2007, 11:16 AM
3.4camaro's Avatar
Quoted from ls1howto.com
Apply the moly lube that came with the ARP bolts to the threads, as well as under the head of the bolt and both sides of the washer. Only a light coating is needed. If you don't have the included moly lube, put some motor oil on the threads.
Torque all 15mm bolts to 30lbft in the torque sequence above.
Do a second pass at 50lbft, and finally a 3rd at 70lbft.
Finally install the 5 smaller ARP bolts and torque them to 22lbft.
The procedure is the same for ARP studs.
Old 09-08-2007, 11:29 AM
7 Second Club
Thanks but I need torque specs on 1/2" and 3/8" fasteners, not factory sized.
Old 09-09-2007, 03:10 AM
siverbullet's Avatar
i did my 1/2" at 110lbs but not sure on the 3/8
Old 09-09-2007, 10:25 AM
427's Avatar
You should use the same numbers as when it was honed. We use a few different ways, but the 1/2 stuff is 100-110 with a torque wrench. The 3/8 stuff we have been using 40. The under bolts can't be done directly with a torque wrench. We use a offset 12 point box wrench on the end of a 3/8 torque wrench. With this set up we torque a lower bolt to 40, then mark the nut exacly at the stop point. Then break it loose and use the box wrench/torque wrench combo with lower settings until you find the number that stops the nut in the same place. Use that number to tighten the upper row.
Kurt
Quick Reply: ARP 1/2? && 3/8" head stud torque specs
