What does code P0100 Mass or Volume Air Flow Circuit Malfunction mean?
Old 08-29-2007, 03:26 AM
ryanisfast's Avatar
Default What does code P0100 Mass or Volume Air Flow Circuit Malfunction mean?
I have this code along with a p1657 which is the 1-4 skip shift, but I just installed headers and I'm surprised I'm not setting a code for the rear o2 sensors. One has cut wires and the other is dangling.
I also plugged up part of the egr, but it's not setting a code either. My car is 97 obd2 lt1. Any ideas??
Old 08-29-2007, 03:30 AM
Formula350's Avatar
Just by reading it, I'd think the MAF is bad.
Old 08-29-2007, 03:36 AM
ryanisfast's Avatar
it says malfunction though... does that mean it's working now??
Old 08-29-2007, 06:39 AM
97blackz28's Avatar
no it means it is not working. how does your car run and idle? as far as the codes for o2 just give it a few cycles and you'll have your SES light, it is not always an instant thing.
Old 08-29-2007, 09:19 AM
ryanisfast's Avatar
is that the maf sensor? My car idles fine... My car does crack and pop a lot though when downshifting.
Old 08-29-2007, 10:22 PM
ThoR294's Avatar
check the wiring and such around the MAF, make sure u didnt screw any of it up when u did the headers
Old 08-30-2007, 12:54 AM
ryanisfast's Avatar
oh I finally took it to the track... All I got was a 13.8@102. With headers and cai I thought I shoul dhvae been mid 13's around 105. I know I have quite a bit of hesitation up top when it gets warmed up, but it was like that before and I still managed a 13.9 stock. I also got a better 60ft of 2.1, but I thought I would have gained more than 2mph with headers and no exhaust besides the ypipe clamped to the headers
Old 03-15-2011, 09:21 PM
jcon104's Avatar
as for the mass air flow code. is there any chance you are running a k&n air filter the circuit malfunction means something is wrong electrically. I ask about the k&n filter because they are a oil based filter. If the filter is not properly oil correctly (normally to much oil) the excess oil tends to gather on the wire or the mass air flow. My suggestion to you it take apart the intake buy yourself a can of crc mass air flow cleaner give the sensor and throttle body a good cleaning. p1657 thats just because of the skip shift elminator. plug it back into trans it goes away thats the only way around that unless you reprogram the computer.
Old 12-04-2011, 12:57 PM
Haney789's Avatar
I'm throwing the same code but my maf is brand new but when I unplugged it it ran fine. Idk what could be wrong with it
Old 12-04-2011, 10:40 PM
MEAN LT1's Avatar
Clear it and see if it comes back.
Quick Reply: What does code P0100 Mass or Volume Air Flow Circuit Malfunction mean?
