Cost of replacing transmission front seal
Old 08-20-2007, 03:45 PM
BeachZ's Avatar
Default Cost of replacing transmission front seal
Can anyone give me an estimate of how much a shop would charge for this?
Thanks in advance...
Old 08-20-2007, 04:19 PM
darom's Avatar
Around $280-360. The mechanic has to pull the tranny and converter off.
Old 08-21-2007, 10:37 AM
WE TODD DID's Avatar
If the front seal is leaking, you most likely have other issues related to that. You rarely see a front seal go bad.
Old 08-21-2007, 10:54 AM
Gilbert@Ace Racing's Avatar
Correct. As an example for folks to see, I keep a worn out tailshaft housing bushing on my counter as evidence of that very specific fact. The trans was old, over time the weight of the driveshaft has simply eggshaped the bushing causing the seal to become disfigured, thus a leak.
To speak to the cost, typically we charge $350.00 to R&R a transmission. If it needs a minor repair we might not bill for that in addition, but it is taken on a case by case scenario. You should plan anywhere between $350.00 and $500.00.. no way to know what it needs until the problem is visually inspected.
Hope that helps.
g
Old 08-22-2007, 11:25 AM
BeachZ's Avatar
Hope that helps.
g
It does help. And I got screwed.
Quick Reply: Cost of replacing transmission front seal
