Where can i buy Liquid Nitrogen in DFW?
Old 08-15-2007, 12:27 AM
Elite_Hot_Rod's Avatar
You don't want liquid nitrogen you want nitrogen gas 2 different things. Liquid nitrogen is used to super cool things, they put nitrogen gas in tractor tires because it doesn't freeze like air, very little moisture.
Old 08-15-2007, 12:30 AM
ckyconan2003's Avatar
....im very sure of what i want. That is Liquid Nitrogen (LN2).
Old 08-15-2007, 12:53 AM
Do you have a container to store it in? IIRC Liquid Nitrogen boils at -212 F.
Old 08-15-2007, 07:54 AM
slayer_taunu's Avatar
i dont think you want liquid nitrogen in your car... you saw what happened to the T-1000
Old 08-15-2007, 08:20 AM
SiL3NtXWS6's Avatar
nitrogen would be a bad idea since it does weigh more than air. so when at a stop all that air is at the bottom of the tire, this would more than likely reduce performance than improve it.
wrong.
air = MM of 28.97 kg/kmol at sea level \
nitrogen = MM of 28.0 kg/kmol
Old 08-15-2007, 12:01 PM
joelvette's Avatar
nitrogen in a gaseous form is used in aircraft tires, for 1. since the molecules are larger the pressure doesn't bleed down as quickly as air, 2. no moisture (water vapor) in nitrogen to freeze at altitude or corrode/errode the metal and rubber parts. nitrogen in liquid form is usually used to supercool parts to shrink them, like installing bearing and bushing. it's also used in cryo-treating of parts after heat treating, but you're going to have to do your own research on that. nitrogen once mixed with another gas will not seperate into layers, ex. check the air outside.
Old 08-15-2007, 02:34 PM
Arachnotron's Avatar
When my buddy worked in the UH physics lab he would bring me liquid nitrogen to play with on occasion.
Old 08-15-2007, 02:49 PM
Take a seal-a-meal bag put some liquid nitrogen in it seal the opening and throw it under your buddies tool box, stand back and watch him jump, lol. Take a 2ltr plastic bottle put a rubber stopper in the opening with a hole in the stopper for a tube to fit in the hole, fill it 1/4 way up with water, pour some liquid nitrogen it and air it up with an air chuck, takes off like a rocket.
Old 06-05-2017, 12:53 PM
terrybrooks's Avatar
am sure you have to place a pre order from a manufacturing firm. You can also purchase bath salts from http://www.bathsaltforsale.com , secured and discrete. i have been ordering from there so i recommend
Quick Reply: Where can i buy Liquid Nitrogen in DFW?
