signs of bad PCM
Old 06-18-2007, 07:04 PM
LT1_King's Avatar
Default signs of bad PCM
i was needing to know if any of you guys have had a bad PCM? what are the typical symtoms if any. let me know of bad experiences.
Old 06-18-2007, 09:26 PM
1slot/a408's Avatar
i would really like to know this too! does a bad computer affect performance? like fuel to injectors and quick heatin? misfires? sorry for askin questions in your thread! i think mine is bad
Old 06-18-2007, 09:37 PM
LT1_King's Avatar
mine has all these symtpoms. my performance is very poor. i would like to really know.
Old 06-18-2007, 10:03 PM
1slot/a408's Avatar
i tried checkin it with the code readers and none read it! hopefully someone helps out!
Old 06-18-2007, 10:12 PM
dhdenney's Avatar
I think failed communications is also a sign of a bad PCM.
Old 06-18-2007, 11:14 PM
LT1_King's Avatar
what do you mean by this? would it be in the wires and stuff? cause i looked at the wires and everything is in place.
Old 06-18-2007, 11:22 PM
siniSSter's Avatar
I had a bad computer on my LT1. Mine just wouldn't start though.
Old 06-19-2007, 06:37 AM
dhdenney's Avatar
1slot/a408 said the code readers wouldn't read it. I am assuming he meant that it wouldn't connect. I thought my PCM was bad once cuz it wouldn't connect. But I looked and the com ports were mismatched on my laptop and I was relieved.
Old 06-19-2007, 06:43 AM
Formula350's Avatar
In my computer experience, when a part goes bad, it's done. When a processor breaks, it's broken. It'll cause instability in the computer, but that doesn't make sense for a car. Cars have solid state components, unlike a computer which has a hard drive. The data gets corrupted and then fragments causing further instability. I don't see how this can translate to a car. If it got bad signals/data from a chip, I would think that it would not only run like ****, but I mean RRREAAAAALLLLLLYYYY shitty. You wouldn't be able to drive. Like an injector would decide to just not pulse, and then next stay open way too long. Sparks would happen at random times.
Old 06-19-2007, 07:31 AM
dhdenney's Avatar
There's a girl on here (Zralou) that said her fans don't come on anymore and she speculated the PCM was bad. So yeah, random ****.
Old 06-19-2007, 12:12 PM
Formula350's Avatar
Something happening, the same way, always, isn't random.
Odd explanation but here goes:
Every day, you're getting 5s. Then something happens and you're getting 2s every day. That's what's happening to Sara. Something happened and her fans don't work and the PCM won't communicate. Now by random, I mean you're getting 5s, then something happens and you're getting 2s, then 8s then 3s, etc. No pattern, total arbitrary randomness. Like my computer right now is on the fritz. It will lock up, or crash a program randomly. I can stress the CPU to 100% for 20mins and nothing will happen, but if it's just SITTING here, it'll crash and reboot. THAT is random. I can play games fine, and it'll crash just the game, and I can load it back up and play like nothing happened heh.
Old 06-19-2007, 03:14 PM
dhdenney's Avatar
Well by random I meant one didn't know what the PCM was gonna quit doing.
Old 06-19-2007, 03:19 PM
buffman's Avatar
I've been wondering about mine. I have this weird miss at roughly 1000-1200 rpm on cold start up only in open loop. Everything is new if not close to new. Sometimes if you start it up, and do something like press on brake, or turn on AC it tries to die, but recovers. Miss is gone above 1500rpm. Once it hits closed loop it dissappears. Unless there's something wrong with MY SVOs, I've been wanting to pick up a spare PCM to see if the problem follows. I've even used my original flash and redid the whole tune, waiting to see if that helped.
Old 06-20-2007, 01:36 AM
1slot/a408's Avatar
i tried havin it read for codes but nothin was able to connect to it! the previous owner had a hypertec programmer to it! any idea if that would of messed it up? any bad experiences with that programar you guys might of heard?
Quick Reply: signs of bad PCM
