Old 04-29-2016, 04:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
Firebird/trans am power window problems
Old 05-25-2007, 05:22 PM
JGWS6's Avatar
Default Firebird/trans am power window problems
I'm wondering if anyone has had problems with their driver side power window, because I am. If so, was it the regulator, window motor, or both that fixed the problem. Mine will go down fine most of the time, but then when you try to put it back up it will go up a little, and then stop. Then you have to wait a while and try again and it will go up a little more. Repeat process until window is up. Not recommended for rainy days. Thanks for any input.
Old 05-25-2007, 05:37 PM
2001NBMZ28's Avatar
Classic symptom of window motor going bad. Get one locally with a lifetime warranty and replace it yourself. Lots of guides out there.
Old 05-25-2007, 07:28 PM
chavez885's Avatar
http://shbox.com/page/windowmotor.html wow we need to sticky the damn window motor problem lol
Old 05-25-2007, 09:38 PM
Blown Ta's Avatar
had the same problem, but on the pass. side, i just finnished replacing
the motor, now it works perfect. replaced the driver side about 2 years ago.
make sure there is grease on the motor gear and track.
Old 05-26-2007, 02:25 PM
Viper's Avatar
Yep, I replaced my driver side in 9-2003. It just died last Monday but AutoZone had me on file so they handed me a new one. So it lasted 4 years, same as the stock one.
Old 05-27-2007, 06:41 PM
JGWS6's Avatar
thank you for the help everyone.
Old 05-30-2007, 06:30 PM
andybme's Avatar
I'm in the process of changing out mine right now and I'll never attempt it again. I talked to one shop that specializes in F bodies and they said change out the whole motor and regulator assembly. Otherwise it's a BIG pain in the *** and I'm finding out the hard way.
Old 05-30-2007, 06:57 PM
BigT2002's Avatar
had it awhile ago, and did it on my own. Took all of 45 minutes tops and thats with zero mechanical ability :biglaugh:
Old 05-30-2007, 08:05 PM
Copy & Paste Moderator
VIP1's Avatar
Its really easy. I've done it twice now. The motor is just held in with a few rivets. No need to remove the regulator. You can do it in 30min - 1hr.
Old 04-24-2009, 05:38 PM
96tealTA's Avatar
That link needs to be a sticky! My motor just went out today. Good thing it wasn't raining. lol
Old 04-24-2009, 06:31 PM
joblo1978's Avatar
Yep, had it happen twice on two different 4th gens. Motor is about done.
Old 04-03-2014, 02:51 PM
IAFFLS1's Avatar
any issues with the rollers on the window track. Mine is broken and I was told it is a discontinued part. How can you discontinue a vital part on a late 90s car that has a history of window problems? Any input?
Old 04-03-2014, 03:32 PM
MTN_Z's Avatar
I think Rock Auto sells the motor/regulator together. Might want to take a look.
Old 07-19-2021, 06:29 PM
Kitt_Down_Under's Avatar
I installed new motor and regulator assemblies from Rockauto about 6 months ago and the windows work super well now! Ive found that Rockauto has lots of parts for these cars that are otherwise impossible to find outside of a junk yard, so I definitely second this recommendation!
Old 07-21-2021, 11:03 PM
Save the manuals!
wssix99's Avatar
This thread was 5 years old, but if you installed the regulators, make sure you used the proper GM rivets. Off -the-shelf rivets or bolts will destroy the door.
We also recommend that members NOT replace the regulator but use the shbox method for motor replacement. This avoids the complexities of regulator changes and keeps longevity of the (fragile) door and the regulator rivet holes.
Kitt_Down_Under (07-21-2021)
Quick Reply: Firebird/trans am power window problems
