where to measure is RING GEAR DIAMETER
Old 03-29-2007, 08:56 AM
jeejee's Avatar
Default where to measure is RING GEAR DIAMETER
forgive my ignorance
but what measure is exactely used to state "ring gear diameter" like a ford 9 inch or 8.5 or 8.8 ?
A , B or C ?
thanks, Jeejee
Old 03-29-2007, 10:47 AM
FirstYrLS1Z's Avatar
I measure the 'A' and you'll find some are 7-1/2 and some are 7-5/8. Both sizes have the same bolt size and pattern and same inside dia. for slipping onto the carrier.
Old 03-29-2007, 11:42 AM
14 Second Truck Club
mzoomora's Avatar
You will also find that higher numeric gears will be larger diameter because of the smaller pinion.
Old 03-29-2007, 11:47 AM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
You measure at " A " ..
Old 03-29-2007, 03:29 PM
jeejee's Avatar
oke thanks, so the biggest diameter is the one to go for
eventhough in theory a 6:1 ratio on a small carrier could mean a bigger RING DIAMETER then a bigger carrier with a 2:1 ratio ?
Jeejee
Old 03-29-2007, 05:49 PM
mzoomora's Avatar
There is no real difference between the 7.5/7.6. The ring gear design was never actually changed, just the pinions looked slightly different and the carriers were slightly different. Getting a 7.6 ring gear in place of an old 7.5 will be no gain, and all the aftermarket stuff is the same.
Old 07-31-2008, 09:58 AM
99Hawk6spd's Avatar
I know I'm dredging up an old post, but could this be added to the FAQ thread on this forum? I was wondering about how they measured these to, and had to search for it, when I think it is a FAQ for some newbs like me.
Old 03-24-2010, 04:36 PM
jeejee's Avatar
Good idea
Old 03-25-2010, 09:52 AM
cambirdracing's Avatar
Not really, just thicker b/c of the smaller diameter of the pinion. You would have to have a shorter in length pinion to have a bigger diameter ring gear.
Quick Reply: where to measure is RING GEAR DIAMETER
