A good block sealer for all you big bore guys.
Old 06-14-2002, 05:49 PM
Resident Grump
Joe Kizzire's Avatar
Default A good block sealer for all you big bore guys.
It's called Dyke and it's made by Conklin. It won't stop your radiator up and it will be there untill you drain it out.
Now you can save the long distance call to the shop that built your high dollar big bore sleeved motor when it starts loosing coolant. Just think of it as an extended warrenty.
Ain't it fun being a car guy!!!!
Joe Kizzire is offline
Old 06-14-2002, 05:50 PM
Terry Burger's Avatar
Default Re: A good block sealer for all you big bore guys.
Joe does Conklin make an additive that will help your solid roller 370ci run 10s NA?
Terry Burger is offline
Old 06-14-2002, 05:52 PM
Colonel's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Terry Burger:
<strong>Joe does Conklin make an additive that will help your solid roller 370ci run 10s NA?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
I gotta admit. You do pull a good one liner every now and then! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Colonel is offline
Old 06-14-2002, 05:57 PM
LSX Mechanic
Damian's Avatar
<strong>Joe does Conklin make an additive that will help your solid roller 370ci run 10s NA?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LMFAO!!! That was good
Damian is offline
Old 06-14-2002, 06:19 PM
SSU Moderator
RyanJ's Avatar
Joe....you just got owned.
Take a nap and think of another good one.
Just to be fair, both comments were funny.
RyanJ is offline
Old 06-14-2002, 07:49 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Wow this thread really turned on Joe, Terry has his moments. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Pro Stock John is online now
Old 06-14-2002, 08:23 PM
SJH
SJH's Avatar
well I wouldn't have a problem using block sealer if a sleeve leaked a tad. A dropping sleeve is a different story though!
Cast aluminum tends to have pores. Not much you can do about that either.
The stock liners in these motors are cast into place so the porous nature of the block is not really going to effect them.
But a press fit liner I can see having a problem every now and then.
You want to see how the aluminum is porous, try polishing it. While doing my chambers at a rough sand they looked great. When polished you can see the pores. Some areas worse than others.Just little air pockets during the casting.
I remember the 4.1 aluminum Cadillac motor from years ago.
When doing a coolant flush , YOU HAD TO ADD A GM organic 6 Pack of stop leak pellets to keep it from leaking.
This was a factory fix!
Joe as long as you have been around I am surprised a little stop leak would bother you <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
If it works who cares if it's a Band-Aid fix.
This is hotrodding man.
I do all my own work also, but even if I paid for a block I would understand this is not a huge issue.
Again, this is different from a dropped sleeve which is serious.
just my .02
Steve
<small>[ June 14, 2002, 09:50 PM: Message edited by: SJH ]</small>
SJH is offline
Old 06-14-2002, 08:54 PM
Tim98TA's Avatar
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
The sealer that Joe mentioned does work. They have a certain way to put it in to make sure it works though. Takes about 2 days to complete.
I tried it last year on a customers Detroit Diesel inline 6cyl turbo engine. He had a blown head gasket and needed to sell the machine. He had tried a few of the local auto parts sealers, but it still leaked. We put this stuff in and I'll be damned it if didn't seal it up. VERY hard to find though.
Would I put it in my new motor that the engine shop charged me $12,000.00-$13,000.00 for? Nope, I say they tear it down and fix it like it should be.
Tim
<small>[ June 14, 2002, 09:09 PM: Message edited by: Tim98TA ]</small>
Tim98TA is offline
Old 06-14-2002, 11:37 PM
Resident Grump
<strong>Joe does Conklin make an additive that will help your solid roller 370ci run 10s NA?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey Terry... A 1.52 and 122 mph don't equal a 10.98.... What did you do stage with the back tires???? Anyway Terry you'll always be in California and will probably never come east so I know I will probably never get to race you so I'll let you live in you et world. Terry racing another car is alot more fun... you should try it.
Old 06-14-2002, 11:39 PM
Resident Grump
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Joe Kizzire:
<strong>It's called Dyke and it's made by Conklin. It won't stop your radiator up and it will be there untill you drain it out.
Ain't it fun being a car guy!!!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Please don't anybody say anything about MTI or the thread will be deleted.
Old 06-15-2002, 02:54 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Damn, Terry doesn't even need to respond to this one anymore, he slapped you down pretty hard with his one-liner LOL!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Hey Terry... A 1.52 and 122 mph don't equal a 10.98</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey, aren't you the same guy that said it was impossible for a 6-speed to run 11.9s with only 118 mph and a 1.7X 60' on drag radials back when I was the first one doing it consistently, in front of an audience, with video cameras, and timeslips? Yep, you sure are the expert to consult! <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Tony
Nine Ball is offline
Old 06-15-2002, 04:23 AM
Colonel's Avatar
OMG, this is too frickin' funny! What a riot!!! <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Colonel is offline
Old 06-15-2002, 09:47 AM
Resident Grump
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Nine Ball:
<strong>Damn, Terry doesn't even need to respond to this one anymore, he slapped you down pretty hard with his one-liner LOL!
Tony</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes Tony and I'm the same one who kicked your *** at Bowling Green with a car that was.04 slower than yours when you miss second gear and blamed it on your super duper clutch. I forget what kind of clutch it was but I'm sure it was somebody you were pimping for.
Tony how come you have not been running you car??? Surely "Mister Six-Speed" himself would be out at the track with hhis Huggybear suit on driving his new 434 super stroker. Tony I hope you get more than just a cut in price and shop ***** time at MTI because you work hard at pimping.
Tony I've been meaning to ask but never got around to it, What ever happened to 99Redhawk??? How come he don't hang out at MTI anymore???? As much publicity as he got for MTI with the magizine article and all it looks like Jason would have gave him half of the place.
Uh oh.... I said the M word... This thread is good as deleted or moved
I know why "The Colonel" is not running his. He's afraid that it will drop another liner before he can sell his motor. Let's see that block was done almost a year ago. That means that it was one of many that was done before Pain's so that's got to be out of the liner droping batch. Hey Steve if a 422 can be bought that cheap why are you asking Twelve grand for a used one that came from the old liner droping batch of blocks from a year ago??? Does the twelve grand include a couple of cans of block sealer???
And Terry I know you're going to say something else about my car only running high elevens so go ahead. I think everybody likes you better when you are on me so maybe with my help you will finnally be thought of as something more than a troll mental problem from California.
Pro Stock Johnny... There's nothing I can say about you that everyone don't already know. However it's nice that you confirm it everytime you post.
And Tony before you are Steve delete or move this thread remember It started out about a good block sealer to use until Terry the Troll chimed in.
Old 06-15-2002, 01:54 PM
kent's Avatar
This is better than a soap opera.
kent is offline
Old 06-15-2002, 01:55 PM
Colonel's Avatar
BTW, Mr. Kizzageration, this block IS one of the "new ones" that MTI does IN HOUSE. Goodness, you just don't read so well or you'd know that by now! <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> And I quote from YOUR OWN locked thread!...
"I too had a coolant loss problem with my original 422 (not a dropped sleeve) but MTI promptly sent me another. Having a great warranty on a hot rod engine that's known to be raced is pretty awesome if you ask me. BTW, the original block was made back when MTI was still outhouseing their block work. The next block they did themselves and it's been flawless."
It was built in like August.
I've not been going to the track because since my divorce the ladies have been keeping me just a bit too busy. <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" /> I'm sure you can relate. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
P.S., this one's locked for...uhh...well, just for the helluvit! <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
<small>[ June 15, 2002, 01:57 PM: Message edited by: Colonel ]</small>
Colonel is offline
Quick Reply: A good block sealer for all you big bore guys.
