GMPP ASA Cam
Old 02-04-2007, 08:34 PM
spazzyfry123's Avatar
Question GMPP ASA Cam
A lot of people put this cam down, yet I have seen dyno numbers VERY close to 400 rwhp cam only. From looking at dyno sheets, this thing has some great torque numbers. About 350 rwtq at about 3K...Very flat torque curve. And with its low lift, you'd really never have to worry about changing valve springs. I used to be pretty set on getting a pretty big cam (MS3, G5X3, etc...), but now I think I may be going with the ASA for its great torque, low lift, good HP gain, and its badass sound. But before I go through with buying a cam, for the people that have owned this cam: What did you like and dislike about the cam? Any cam surging at low RPMs? How's its drivability? What valve springs did you use (LS6 or 918's)? What length pushrods would be needed? I've seen a couple people using 7.425. How does this cam react to N2O?
My car:
1999 Camaro SS six speed
4.11 rear gear
Lid
Pacesetter long tubes
Custom X-pipe with Dynomax Bullets; open headers right now, though (might be changing to something else soon)
~19,500 miles on the car
Daily driver
Also, just curious...What are the factory cam specs for a '99 LS1 for comparison?
I'm sure there are many more questions to come, but until then...Thanks!
-Tyler
Old 02-04-2007, 09:35 PM
68protouring454's Avatar
i got a asa ls 1 motor and i want to hear the same info. got motor,oil system with scavenge pump, wiring,ecu, etc, i have read install asa cam and gm race heads, 500 hp at crank
jake
Old 02-04-2007, 09:44 PM
Hell'sChariot's Avatar
Also how would this work with a 4k stall.
Old 02-05-2007, 09:03 AM
jfrc2000's Avatar
what is the design of this cam for? is it for roadracing, such as continuous high RPM's, etc...
i have an older buddy who bought it off ebay, he thought it was a little bit bigger than stock
Old 02-05-2007, 09:06 AM
Stang's Bane's Avatar
Just because of the low lift, don't assume that it is easy on springs. It has been stated once, that if not sewtup properly, this cam will EAT springs.
Old 02-05-2007, 10:00 AM
JRracing's Avatar
A friend of mine has a ASA motor out of a race car with a few laps on it. He just put it in a 99 SS with lots of other mods in it. A4 with 4K verter. I'm very excited to see what it does. He ran low 12s with stock internals and stock exhaust.
Old 02-05-2007, 10:26 AM
jmm98LS1's Avatar
Pro's:
-Awesome torque, respectable hp
-Idle gives instant chub
-No valvespring worries
-Quiet valvetrain
Con's:
-Takes awhile to tune
-Not going to make huge peak HP cam only
I really like mine. It requires good tuning to get it to idle steadily, but that's true of any of the bigger cams as well. I used the yellow LS6 springs, stock length pushrods. The ASA has a ramp rate of 56, so it's not going to eat springs like lsk or xer lobes. Haven't had mine to the track or on a dyno but I plan to throw a 150 shot on it this summer & see what kind of times she'll run, then some ported ls6 heads should add to the grin factor.
Old 02-05-2007, 12:04 PM
68birdls1's Avatar
i plan on goin with this cam as well! i was set on a big cam only setup, but i didnt want to have to deal with the changing of the valve springs. and besides if your car is going to be mainly a street car then this cam would be perfect
Old 02-05-2007, 01:44 PM
vettenuts's Avatar
What are the cam events and overlap, does anyone know? Would like to plug it into the DCR calculator.
Old 02-05-2007, 04:19 PM
jmm98LS1's Avatar
Overlap is 11*.
Unfortunately this is the only information on the ASA that's been posted here:
https://ls1tech.com/forums/showthrea...=asa+cam+specs
I've searched high and low and have never come across any published specs other than duration @ .050". Sure would be nice to know the valve events.
Old 02-05-2007, 06:14 PM
What would be an example of being "not setup properly"?
Old 02-05-2007, 06:23 PM
Originally Posted by jmm98LS1
Pro's:
-Quiet valvetrain
Con's:
Thanks for popping in here, Jeff! From what I understand, you can throw in a set of those LS6 springs and never have to change springs again; is this true? I saw a set of LS6 springs (16) on SDPC2000.com for only $52.25 As seen here Part # 12499224. Are these the springs to get? It's just hard to believe that one can get an entire set of them for such a low price.
Also...with the pushrods, did you go with hardened or just use the factory ones?
Old 02-06-2007, 08:36 AM
jmm98LS1's Avatar
I ran stock pushrods for a year with no problems, then put a hardened set in for peace of mind. Those are the correct springs, I got mine for $55 shipped. For all intensive purposes, you shouldn't have to touch the ls6 springs again with the ASA.
Old 02-06-2007, 08:42 AM
Grand am cam thread
Look at the post by Sstroker Ace.
I guess what i meant to say was you couldn't just install and forget this cam.
My Bad
Old 02-06-2007, 05:35 PM
Well damn, that's awesome! Thanks for your help, man!
Old 02-06-2007, 05:40 PM
Grand am cam thread
My Bad
This thread is about the ASA cam, not the Grand Am Cup cam...
ASA= 226/236 .525"/.525" 110 LSA
GAC= 239/251 .570"/.570" 106 LSA
Definitely two different cams.
Old 02-06-2007, 06:07 PM
GR33N GoblinM6's Avatar
so this ASA cam.. would you say its a good Road Racing cam? how about this 110 LSA, how do our computers like it?
i was going to go with a 224 224 575 575 114lsa cam.. but i am more into the road racing canyon driving.. i never drag race..
Old 02-07-2007, 03:02 PM
I'm pretty sure this cam is aimed towards road racing. Don't quote me on it, but that's what I've heard.
Old 02-07-2007, 03:04 PM
Well I plan on getting this cam relatively soon. What I need to know is this:
What all is needed for a complete cam swap. Can I just buy the cam, the springs, and pushrods and be done with it? Or are there other little things that are required?
Old 02-07-2007, 04:00 PM
35thUCF's Avatar
I would also like to know, and what about this cam allows it to "eat"springs, allz I need are Ls6 Springs, right ?
Quick Reply: GMPP ASA Cam
