PO342, Camshaft Positioning Sensor ?
Old 04-28-2002, 10:18 PM
TRYMYZ's Avatar
Default PO342, Camshaft Positioning Sensor ?
My car recently died while driving it. The codes that were stored were the 2 for my rear O2s and a PO342 - Camshaft Positioning sensor low input. The car turns over, but wont start. I can hear the fuel pump cycle. I am kind of thinking that I broke the timing chain. Would this code be a symptom of that ?? Where is the camshaft positioning sensor ? Tomorrow I will pull a valve cover and turn the car over. If the valves dont move then that is my problem.
Thanks in advance for the help.
John
<small>[ April 28, 2002, 10:18 PM: Message edited by: TRYMYZ ]</small>
Old 04-29-2002, 07:24 AM
TRYMYZ's Avatar
Default Re: PO342, Camshaft Positioning Sensor ?
TTT
Old 04-29-2002, 09:12 AM
C5 Tweaker's Avatar
Yep, had the same thing on friday - timing chain.
If you remove the oil fill cap, you can likely see a rocker enough to realize it is not moving.
You may also notice that it cranks more quickly due to lack of compression in some or all cylinders.
Old 04-29-2002, 09:59 AM
TRYMYZ's Avatar
Cool. Not that bad of a swap. it could be worse. Are you running heads/cam.
John
Old 04-29-2002, 11:20 AM
LS1Tech Sponsor
Slowhawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by TRYMYZ:
<strong>Cool. Not that bad of a swap. it could be worse. Are you running heads/cam.
John</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not that bad <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I would figure some valves would be stuck open.Which in turn the piston will nail them and bend the valves.
How many miles are on your car?
Old 04-29-2002, 06:11 PM
TRYMYZ's Avatar
So far it doesnt appear that I bent any valves. I checked the driver side and the they seem to hold air. When I release the hose all the pressure comes out the fitting in the spark plug hole. I will check the passenger side tomorrow.
John
Old 04-30-2002, 12:01 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,090 Likes on 718 Posts
Take off the oil fill cap.
If you snap a chain you will bend a bunch of valves.
I did that last year.
Old 04-30-2002, 12:44 AM
Quickin's Avatar
I had that sensor fail, it's been my only problem so far with the car, Your symptom is exactly what I had and the same code. Pep Boys couldn't figure it out (no code), my friend with a diagnostic couldn't figure it out (no code), the dealer found it in 10 minutes. The tech told me that that code sometimes won't show itself, he changed it out, if I remember correctly it was $43.00 and it ran perfect again. I also had 6 other codes which were coils and wires, but it was all caused by the "Crankshaft Position Censor". Nothing was damaged. However, he said major damage could happen if I kept trying to drive it like that. Mine would both suddenly die or drive OK for a little while (maybe 10 minutes) and then die. Sometimes it wouldn't start for 6-8 tries in a row.
To the dealer.
Old 04-30-2002, 11:02 AM
TRYMYZ's Avatar
When I turn the car over the valves dont move so I am pretty sure its the timing chain.
Old 04-30-2002, 05:05 PM
WILWAXU's Avatar
You and Keith live under the same sign? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 04-30-2002, 09:58 PM
TRYMYZ's Avatar
Yeah we do. I just pulled everything out of the car today. Heads, radiator, Cam etc.. The timing chain was definitely busted and I bent at least 2 valves on each side. So the heads are going back to MMS to get setup by them. So is the cam, because I am getting the big daddy 229v2.1. It only took my friend Lino and I 3 .5 hours to tear the car down.
John
Old 05-01-2002, 07:57 AM
WILWAXU's Avatar
Sorry to here man!
Let me know if you need anything!
Quick Reply: PO342, Camshaft Positioning Sensor ?
