Intake Elbow
Old 01-20-2007, 05:48 PM
Leadfoot381's Avatar
Default Intake Elbow
Anybody know where i can purchase a 90 degree elbow to make an cold air intake for my LS1?
Old 01-20-2007, 05:57 PM
TT402LS1's Avatar
Street & Performance makes a real nice AL one. $140.00 polished - $175.00 chrome. They also make a 3 pin MAF $45.00 polished - $70.00 chrome.
Ron
Old 01-20-2007, 07:01 PM
icantdrift's Avatar
i got mine from intakehoses.com, just a heavy duty rubber piece. don't remember the price but it was relatively cheap.
Old 01-20-2007, 07:04 PM
bczee's Avatar
I got my parts from Jagsthatrun.com
Old 01-20-2007, 08:36 PM
sawzall wielding director
G-Body's Avatar
If you want to look locally look for a place that sells diesel truck parts. The intake elbows and tubing are common replacement parts for them and the larger truck part distributors will even have some in stock.
Old 01-21-2007, 01:06 AM
Rodder's Avatar
I got mine from intakehoses.com, part # 90HL40R35 Reducing Elbow 90 Degree 4inch ID to 3.5inch ID $16.70. The setup pictured below is temporary until I figure out where I'm going to get cold air from... my current thinking is cutting a big hole in the core support, adding another bend at the filter, and creating an air box for the filter. I'd really like to come up with something slick using the cowl induction though.
Old 01-21-2007, 07:51 AM
LS1MCSS's Avatar
Check out this post for the cowl induction setup.
https://ls1tech.com/forums/conversions-swaps/643850-chevelle-cowl-induction.html
Old 01-21-2007, 10:37 AM
76LQ9TA's Avatar
You can also look at a CAT dealer or buckhorn rubber. I got a 4" 90, 60, 45 and 22 degree elbow to try and I got a 4" aluminum tube from mymetalconnection.
Old 03-15-2007, 11:53 AM
SimplyKC's Avatar
What do they charge for an elbow?
Old 03-15-2007, 01:43 PM
Indyjc's Avatar
I'm looking for an elbow from a gto. Seems like it wouldn't be to expensive. I believe I saw one in Hot Rod mag.
Old 03-15-2007, 04:06 PM
76LQ9TA's Avatar
I don't remember their exact prices. I have a 4" 68 degree and a 4" 22 degree elbow left over that I can sell for $30.
Old 03-16-2007, 02:48 PM
LS1Tech Co-Founder
Nine Ball's Avatar
I built my own from 3.75 mandrel bent exhaust piping (stainless). TIG welded the elbow, ground it smooth and had it chrome plated. The arm I welded on is where it mounted to the top of the radiator.
More pics of the car here: www.ExtremeG.net
Old 03-16-2007, 03:14 PM
tuske427's Avatar
If you wanna go really low buck- here's the recipe for my "Home Depot" CAI.
all located inthe plumbing section...
1x- 3" rubber elbow
1x- coupler
1x 1' section of black PVC pipe.
To get the elbow to fit the throttle body I had to heat the one end with a heat gun and stretech it over to fit.
The pvc pipe was trimmed to length and I drilled one hole for the AIT sensor and used a grommet to plug it in.
It's not a showpiece but it works and it's on a budget. I'll probably go back and get or make a nice show piece one later on.
Quick Reply: Intake Elbow
