Hummer H3 swap
Old 01-07-2007, 01:20 PM
silicone boy's Avatar
Default Hummer H3 swap
I've searched the internet for info about swapping out the Hummer's 220 hp I5 and found little info, (a 5 cylinder in a hummer? what was GM thinking ). GM keeps promising a V8, but they haven't delivered. I looked at the engine bay and boy does that engine take up a lot of room. I have a spare LS1 from a Camaro SS sitting around, and I was thinking it would bolt right up to the 460LE. It should be an easy swap. I'm looking for input from you guys because I respect you knowledge a lot. I'm thinking I may have oilpan issues-I may have to find other ones or make one. I may have to get a higher volume fuel pump. Other options I have considered are one of the LS truck motors from the Yukon or Suburbans. There is an outfit in Witchita Kansas called Mash Motors that does that swap, but they want $14 K . Another neat option I have considered is to get one of those 5.3 liter flexfuel engines. Should also swap in nicely. Any thoughts?
Old 01-07-2007, 01:27 PM
kickassT/A's Avatar
never seen it done, but it sure needs it. h3's are turds
Old 01-07-2007, 02:37 PM
Fuzzylogic's Avatar
Both ideas sound very cool.
Old 01-07-2007, 07:00 PM
philntx's Avatar
GM had a 5.3 H3 Hummer at SEMA. It looked pretty good.
Exterior:
Engine Bay
Interior:
Old 01-07-2007, 07:44 PM
Cop Car's Avatar
it would be the same swap as any of the Colorados, and i know several guys are doing or have done those swaps. keeping the awd might be a problem. also, in the future there may be a V8 option and that would give you tons of parts to work with.
Old 01-08-2007, 12:15 AM
Keith's Avatar
With the interchangeable bellohousings on the late 4L60E's, I dont see a problem in bolting up a LSx. The only problem might be the oil pan and crossmember/diff clearance. I wonder if a trailblazer pan would work?
There are multiple pans out there though:
C5
Camaro/Firebird
Truck
CTS-V
Monaro/GTO
Trailblazer
Old 01-08-2007, 02:13 AM
It's all good to hear, and those pics are encouraging. The more I stare at the engine bay, the more I think that a V8 swap with a Vortec or LS series engine would not be that hard. This would be my third, (twin turbo SBC into a Datsun Z, 427 LS into an RX7) so putting a GM into a GM seems a lot less complicated.
Old 01-08-2007, 10:09 AM
screamin seeman's Avatar
The engine bay looks exactly like a colorado's. If they are built on a similar platform, I would be able to help you out.
Old 01-08-2007, 10:24 AM
philntx's Avatar
I looked under the truck, but I couldn't get a clear shot of the bottom of the engine or the exhaust routing.
Old 01-08-2007, 10:54 AM
Yes, I read your thread about the Colorado swap with great interest. Good job. The mechanical part of the swap looks straightforward. I liked the oil pan mod. Did you get the guages to work right with the new harness?
Old 01-08-2007, 05:31 PM
Still working on that. I haven't been able to run it because I am having trouble finding a computer that will run the ls2 and supply class 2 data to the rest of the truck.
Quick Reply: Hummer H3 swap
