99-04 Mustang: LS1 swap which K member
Old 01-03-2007, 02:01 PM
7 Second Club
Phil99vette's Avatar
Default 99-04 Mustang: LS1 swap which K member
Should I get a K member setup for the older style 5.0 mounts or the standard 4.6?
Old 01-03-2007, 04:18 PM
m1a2drvr's Avatar
AJE andrew jones engineering makes a nice tubular setup for Chevy small block you just need adapter plates.
Old 01-03-2007, 05:46 PM
ls1stang's Avatar
I used a 4.6 k-member, and had no problems.
Jamie
Old 01-03-2007, 05:48 PM
gyrene2003's Avatar
wow, now thats a cool project!
Old 01-03-2007, 05:56 PM
7 Second Club
Here is the plan:
2000 Mustang V6 5 speed
Iron LSx 402"
PRC S3 LQ9 heads && Carb style intake
ARP studs top and bottom
Splayed main caps and coatings top to bottom
Precision 96mm turbo with air to water IC
We'll make the headers here
Standalone ECU
Wolfe Racecraft 10 point cage, chute, window net, sub frame connectors, upper and lower control arms
Weld Aluma Stars
MT Slicks and skinnies
sheetmetal rear wing
VFN 5" cowl hood
That will get us started...
Old 10-04-2008, 01:38 PM
LS203KOBRA's Avatar
Ls1stang Can You Post A Pic Of Your 4.6 K-member For Me I Have A 2000 Mustang That I Well Put A Lsx 454 In It
Old 10-04-2008, 01:59 PM
7 Second Club
Holy Old Threads
Quick Reply: 99-04 Mustang: LS1 swap which K member
