12455209 - WS6 Lower Air Box
Old 12-10-2006, 07:20 AM
JEB99TA's Avatar
Default 12455209 - WS6 Lower Air Box
Been searching for specifics, but, can't find the right answer. I have a stock '99 Trans Am airbox with FRA mod (bottom of box is cut out). When I buy a factory WS6 Lower Air Box for $74.11 from GM PARTSDIRECT.COM, what else will I have to buy to make my new US Exotics WS9 hood fully functional for Ram Air?
Old 12-10-2006, 10:04 AM
WILWAXU's Avatar
That should be it...
Old 12-10-2006, 03:56 PM
JEB99TA's Avatar
Thanks John ... so I won't need to seal the bottom of my current airbox where I did the FRA? Do you mean this GM OEM WS6 whole airbox comes with the lid to replace my current airbox and lid? A lot cheaper than I thought ... if this is the case.
Old 12-10-2006, 04:07 PM
LS1obsession's Avatar
If you are purchasing the lower air box, you will not receive a new lid. You will not need one anyway, since the WS6 lids are the same as the non-WS6 lids. If anything, order a new aftermarket lid by SLP, TSP, etc.
When you get anything installed, let me know if you have any clearance issues. I have an SLP lid with the stock lower air box (and WS9 hood) and the hood leaves marks on the top of my lid. That is why I am been reluctant to buy the WS6 lower air box, because it may raise the lid enough to where it will not clear the hood.
Old 12-10-2006, 05:17 PM
JEB99TA's Avatar
I guess I just don't understand how the hood adapts to the air box to make the ram air 'nostrils' seal against the airbox to provide a path for air to enter the throttle body from the fornt of the car. I have an aftermarket lid, but, I thought the lid had to come off to swap with a lid which has grate-like openings which passes air through the top of the lid ... hope this makes sense.
Old 12-10-2006, 05:20 PM
On the tree
Sneakyws6's Avatar
The LS1 cars are not a actual ram air like the LT1 care were. The air is directed towards the front of the air box. The ram air box is almost 2" tall where the non ram air box is only 1/2" to 3/4" tall at the opening.
Old 12-10-2006, 06:21 PM
JEB99TA's Avatar
So, the air is pushed through the front opening of the airbox and into the bottom of the airbox there?
Anyone have pictures of the WS6 or Firehawk airbox that you can post?
Old 12-10-2006, 08:25 PM
Correct. Then, it is sucked up through the air filter and into the throttle body.
Sort of like this:
.......................................^>>>>>>>>in to throttle body/engine
...................................(air filter)
flow into lower airbox>>>>>>^
Old 12-10-2006, 08:44 PM
1998-2002 WS6 Ram Air
1998-2002 Standard Air Box
1998-2002 Sun Coast Creations Ram Air
1998-2002 K&N Filter only set up
LT-1 WS6 Ram Air
Old 12-11-2006, 05:44 AM
JEB99TA's Avatar
You don't know how much I appreciate you posting pics. Thanks a ton my friend!!!
Old 05-13-2020, 01:26 PM
Bubba512's Avatar
Can please please tell me the part number for the filter for the suncoast creation hood? I have no idea what it is, been looking for months now.
Old 05-13-2020, 03:37 PM
Received 3,018 Likes on 2,349 Posts
You really expect a reply on a 14-year old thread??
Old 05-13-2020, 04:31 PM
Bubba512's Avatar
I knew it was long shot but guess what....I did get a reply. Soooo, do you know or not?
Old 05-13-2020, 05:46 PM
If it's still made, Google it. You never know....
Quick Reply: 12455209 - WS6 Lower Air Box
