PIC of Crank Sensor for 95 T/A LT1
Old 11-03-2006, 09:09 AM
mack's Avatar
Default PIC of Crank Sensor for 95 T/A LT1
Anyone got a pic of the crank senor or can you be spacific and explain its location please.
Old 11-03-2006, 09:28 AM
streetwarrior96's Avatar
thought the 96 and 97 had them
Old 11-03-2006, 09:35 AM
mack's Avatar
Well the scanner is pulling a code 18 and saying that it's a crank sensor. The book says a code 18 is the injector driver.
Problem is: number 3 & 8 injectors are not firing correctly and I'm dropping cylinders. Hooked a nood light and they intermittenly like their loosing ground.
Old 11-03-2006, 09:44 AM
Well the crank sensor is at the bottom of the timing cover
Old 11-03-2006, 10:12 AM
grn95t/a's Avatar
yes i belive just the 96 and 97 had them. my 95 doesn't.
Old 11-03-2006, 10:37 AM
mack's Avatar
Okay, Thanks guy's. I didn't think it did either. Now I can rule that out.
Old 11-03-2006, 11:02 AM
Fire67's Avatar
The being that the code said crank sensor, and the book said injector driver, could it be the optispark?
The notched wheel inside the opti provides crank and cam position data to drive the injector and spark timing.
Maybe some of the wiring to the opti is damaged or you have an intermitent(sp?) short somewhere in the circuit.
Try pulling the plug from the top of the opti... Sometimes it gets corrosion damage and a good cleaning of the contacts works wonders.
Old 11-04-2006, 03:43 AM
infinitebird's Avatar
code 18 is an injector or wiring problem
Quick Reply: PIC of Crank Sensor for 95 T/A LT1
