How to hookup 4L60E trans lines @ transmission???
I have the nut on the trans, a flared line, a white plastic thingy, a red plastic cover, and an "E" clip. How does the trans line go/stay in there? I am thinking that it goes into the nut, the nut is tightened down, holding the line in place, then the white plastic thing is slid over the line/fitting junction, then the "E" clip is installed over the white thing, holding it all together, is this correct? Can anybody shed some light on this for me? I didn't take it out, and I need to figure out how to put it back together, ASAP. Thanks, Shawn
<img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> 4L60E <img border="0" alt="[fight]" title="" src="graemlins/gr_punch.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> converter install <img border="0" alt="[bullshit]" title="" src="graemlins/gr_bs.gif" />
Re: How to hookup 4L60E trans lines @ transmission???
No wrenches are required for this. You dont need to loosen or tighten the nuts (unless you are swapping with another tranny). Push the line in. Install E-clip through slot holes in fitting. Slide white plastic retainer over fitting and E-clip. Slide red plastic disc up to backside of white retainer.
I just went through this last week. You need to put the e-clip in the fitting first, make sure all three tabs on e-clip can be seen inside fitting. Push the cooler line into fitting till is snaps in place. Slide the white plastic ring over the fitting and e-clip to hold everything in place. Make sure you give the line a good yank to make sure the line is in securely.
Have Fun.
Dee Jay
Have Fun.
Dee Jay
