broken rocker arm
Old 09-19-2006, 02:54 PM
Ima get mines's Avatar
Default broken rocker arm
Is it going to mess up anything If I drive my car around with a broken rocker arm? Its not exactly broken but the bearings wore out in one and I found some in my oil pan. I can hear a ticking noise from it but so far it hasnt affected the drivability of the car. I want to replace it this week.
Old 09-19-2006, 03:57 PM
Thule's Avatar
i would NOT drive it..
Old 09-20-2006, 11:01 AM
Disturbedtransam's Avatar
How loud is it....
Old 09-20-2006, 12:15 PM
GuitsBoy's Avatar
Dont drive it. Take a taxi cab to the local dealership and buy a new rocker, IIRC theyre only like 14 bucks or something really cheap like that. It only takes a few minutes to swap it out. While youre at it, change your oil to flush out the rest of the needle bearings.
Old 09-20-2006, 12:30 PM
Here it is, Its a wonder it didnt fall off.
Old 09-20-2006, 01:41 PM
How easy is it to fix?
99_Z_155's Avatar
yeah. dont risk it man. go and get a new rocker and throw 'er on there.
Old 09-20-2006, 01:46 PM
Its real easy, these rockers require no adjusting, I just bought a used stock set and bolted it on. Some guides on the internet say you have to disconnect a fuel line to remove the driver side valve cover but thats not true, I just rested the valve cover on the header and removed the back rocker, put a new one on and tightened it down to 22ft/lb of torque.
Old 09-20-2006, 02:33 PM
How bad did it sound?
