th350 pan torque specs.???
Old 09-09-2006, 12:20 PM
redtail2426's Avatar
Default th350 pan torque specs.???
Anyone know what the torque specs are on these th350 oil pans.And are there rubber gaskets for these.I have a cork style and its leaking i think.
Old 09-09-2006, 12:54 PM
FLT
FLT's Avatar
I usually torque the bolt's to 110inlbs. Make sure that were the bolts go through the pan that the surface is flat and not dished. Also make sure that the pan rails are flat as well. I have seen some different gaskets for these pans. I have never used a rubber style before. I use either the cork style or the durapreme gaskets with a good straight pan.
Quick Reply: th350 pan torque specs.???
