C6 Corvette Wheels... What tire size???
Old 08-09-2006, 07:32 PM
dubtheincredible's Avatar
Location: Where the Navy sends me. I'm from and call Georgia my home though.
Post C6 Corvette Wheels... What tire size???
Another please help!
I just won a set of C6 vette wheels off of ebay and need to know what size tires to run. The fronts are 18X8.5 and the rears are 19X10. I'm not trying to push the limits I just need to know what will fit and if I need any spacers. I noticed on SLP's website they sell a spacer for 17s do I need this or do I need something bigger for the 19s? Thanks for your help and if you can thing of any other helpful hints or know something I should know shoot it my way.
THANKS Y'ALL!
Old 08-09-2006, 07:50 PM
nvrlast's Avatar
im running c6 replicas and i dont need a spacer but it sounds like you are runnin the real thing so you probably willneed one. Im not sure what size spacer but do your home work on witch brand to buy. My cousin has a set and the lugs keep snappin on them. I dont no wich ones he has but they were dirt cheep. As far as tire size you could go with like a 285 thats what im runnin on my 18-9.5's I know there not 19-10 but I wouldnt go wider with out doin enough research because mine sligtly rub in the back. for the front you can go with a 275.
Old 08-10-2006, 02:22 AM
di0ck's Avatar
go with the corvette stock tire size..
if im not mistaken... 255 f / 285 r
Old 08-10-2006, 10:52 AM
01ws6450hp's Avatar
I am running 295/35/r18's on my 18x11 Z07's and just had to do the BFH mod. The fronts are 255/35/R18's on a 9.5 wheel.
Old 08-10-2006, 11:57 AM
Teri9672's Avatar
I'm running the stock C6 runflat tires. You will need spacers and longer wheel studs
Old 08-10-2006, 12:24 PM
MonsterZ28's Avatar
I'm lookin at 19x11 out back.... will wheel adapters work?
oh and 01ws6450hp, what are z07 rims?
Old 12-18-2010, 08:11 PM
U.S Army Soldier's Avatar
will the c6 corvette wheels fit directly on my 94 SS or do i need to get adapters for them
Old 12-18-2010, 08:27 PM
Oso SS's Avatar
lol this is a really old thread BUT since I'm selling my 18/19 combo I'll help you out.
First, they didn't make a 94 SS so I'll assume you're talking about a Z28.
Either way, you'll need a spacer or adapter, 1" in the rear should work, I didn't run one at all in the front and didn't have problems.
I had already cut out the bump stops and did the BFH mod to the rear so I put a 1/4" spacer and it worked fine.
Old 12-19-2010, 12:48 PM
BandDirector Blk98ZM6's Avatar
I had OEM C6 rims...but didn't keep them long because the 30 series tire on the rear just made the ride too rough AND I couldn't get traction. However, if you run OEM C6 rims on a 4th Gen. Camaro, you need to run 255/35/18 tires on the front 18x8.5 rims and 275/30/19 or 285/30/19 on the rear with a 1.25" adapter/spacer.
I don't like the look staggered rims on an F-Body, so I sold the the front 18x8.5's and went with the rear 19x10's all the way around with 275/30/19 tires. But as I said, I didn't keep them long before I stepped back down to 18" rims. I'm attaching pics of the 19x10's all the way around as well as the type of 1.25" adapter/spacer you'll need for the rears. The adapter/spacers are available on eBay for around $65-$70 shipped.
Also, I had just let the car down when I took these pics and the front end had settled yet...it did level out after I drove it.
Quick Reply: C6 Corvette Wheels... What tire size???
