Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
biggest tires on 01 c5?
Old 05-31-2006, 10:04 PM
bashc5's Avatar
Default biggest tires on 01 c5?
anyone know the biggest tire size i can run on my stock 01 c5 rim for the rears? would a 305 fit with no problems?
Old 05-31-2006, 10:31 PM
Assassin's Avatar
I run 315's on z06 rims and you can still fit a finger between the tire and wheel well..
Old 06-01-2006, 10:13 PM
bashc5's Avatar
hum,so nobody on ls1tech knows the biggest tire size that can be mounted with no problems on stock c5 rims? any help would be appreciated..
Old 06-02-2006, 05:19 AM
PA Z06's Avatar
you should be ok with a 305, I know that with a z06 back rim the biggest you can go is a 315, and I believe a c5 wheel is a lil smaller.
Hope that helps
Old 06-02-2006, 06:35 AM
V-seriesTech's Avatar
On STOCK C5 wheels...I run 295's. Certain brands, ast differently on the wheel. Some are wider,...etc. For example, I had Goodyear F1's(factory stock C5 Z06) and they buldged slightly. Now, I have PILOTS....same size, yet, the wheels are nearly as wide.
295-35-18's.
Haven't tried 305's yet.
Old 06-02-2006, 01:28 PM
GTFORMULA's Avatar
I have 335-30-18's michelin pilot sports on my 18x10.5 Z06 motorsports. And yes they bulge out some but thats ok with me.
Old 06-02-2006, 02:11 PM
nc z28's Avatar
on a stock c5 wheel id think you'd have some trouble with a 305
Old 06-02-2006, 02:33 PM
MGorman's Avatar
On stock C5 (non Z06) wheels the largest size tire you want to go with on the rear is 295/35. Even this is larger than recommended for a 9.5” wheel, but it has been proven to work fine.
A 265/40 or 275/40 is recommended for the front to keep the front to rear tire height differential in the correct range (to keep the active handling and traction control functioning properly).
Old 06-02-2006, 10:45 PM
bashc5's Avatar
i appreciate the info guys..thanks.
Old 06-03-2006, 09:42 AM
RunNE1's Avatar
I also ran 295's on my C-5 9.5" rims. Worked great.
Old 06-03-2006, 09:52 AM
cantdrv65's Avatar
Post
I run 335/18 nittos drags on my stock Z06 10.5" rear wheels. yes they bulge a bit but hook great! I had 335/18 Pilot sports on the wheels before and they DID NOT bulge. Also 305/18 nittos fit the stock Z06 wheels perfectly.
Quick Reply: biggest tires on 01 c5?
