Puff of Black Smoke?????????
Old 05-30-2006, 04:53 PM
Take 2's Avatar
Default Puff of Black Smoke?????????
I have had ppl tell me my car is puffing black smoke when I first Nail it???? What do you guys think??? Someone told me I need A catch can and one has told me Get ready to pull the heads or the motor !!!!! This sux please help you guys know more about these things than me ......Whats up????? Sorry if this is the wrong place to ask also
Old 05-30-2006, 04:59 PM
Mike02Z's Avatar
You sure it's not blueish smoke? Known issue with the PCV allowing oil into the intake. Causes blueish smoke under WOT. Catch can would help solve that so would a thicker oil. Lemme guess, Mobil 1 5W-30 is what you use?
If it is black then might want to try some Seafoam. If there is carbon build up it may help get rid of that.
Old 05-30-2006, 05:05 PM
03 BUSA's Avatar
This is a normal condition of the LS1. It is probly blue and it is caused by the poor design of the pvc system. It is actually benifitial to the exhaust valves believe it or not. The exhaust valves take a beating and the oil keeps them lubricated and cooled. The less restrictive your exhaust system is the more noticable it is going to be. And if it is black smoke on accel it is just carbon and other dirt that has collected in the exhaust system and when you go wide open it just blows all the crap out. You should have nothing to worry about. Don't listen to the guys telling you to get ready to pull your motor apart.
Old 05-30-2006, 05:08 PM
00T\A's Avatar
Black smoke is problay just carbon especially if you have cats mine does that.
Blue smoke is definatly oil.
Domestic Demon's Avatar
Its actually not abnormal for a vehicle with a free-flowing exhaust to blow a puff of black smoke when you first get on the gas. When you start up and drive your car under daily driving conditions, carbon gets built up in the engine and the exhaust system. When you floor it, that carbon gets blown out the exhuast, which is the black puff of smoke you are talking about.
If it does it all the time run some seafoam and fuel injector cleaner through the engine, might be dirty in there
Old 05-30-2006, 05:20 PM
Take 2's Avatar
PPl just started telling me this after I installed my LT's and ORY ?? And my wife says it is Black not Blue so I have to take her word for it she has rode behind me many times and she says it only did it once each time. I love my car and I hate it when ppl try to talk **** about it.
Old 05-30-2006, 05:28 PM
jimmyblue's Avatar
The inside of headers & ORY will load up with soot to be
blown out once exhaust gas flow gets serious. Sustained
black smoke (not to mention the residue) probably has
to do with the excessively rich factory tune, not to say
it can't be made worse by some mods (such as headers
causing mis-trimming and positive fuel trims that carry
over onto an already-rich WOT tune, not to mention the
stuff like cat overtemp protection shoving excess fuel
down it to protect something that's not even there now).
Old 05-30-2006, 05:52 PM
2K2WS6TA's Avatar
The puff of black smoke was there all the time, it's just the cats were taking care of it, now you have an ORY, you no longer have cats, so you see the smoke
It's made worse by the fact LTs make the car run richer (in general)
Old 05-30-2006, 07:08 PM
Take 2's Avatar
So will a tune help??? If so where is the best place in houston?? And how much?
Old 05-30-2006, 07:42 PM
2K2WS6TA's Avatar
A tune would help, but how long have you had the headers on, it takes some time for the PCM to adjust to the freer flowing exhaust
As for who in Houston, post in the Texas section, they should know better than anyone
Old 05-30-2006, 07:46 PM
Take 2's Avatar
I have only had the Headers on for 2 days, And thanks a ton for all your help guys I hope it stop because its getting old
Old 10-27-2010, 01:31 PM
buzb026's Avatar
sorry to intrude in the thread but i have a 2000 T/A bone stock and i have also been told that mine puffs out some black smoke when i punch it. do you guys still think its just because of the rich tune from the factory?
Old 10-27-2010, 02:01 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
That is a 4+ year old thread you bumped! That may be a record (for this week anyway)!
Yes, I would highly recommend getting tuned!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Quick Reply: Puff of Black Smoke?????????
