Advantages/disadvantages of SD?
Old 05-19-2006, 11:01 AM
GuitsBoy's Avatar
The main advantage I see for SD is that you can get rid of the intake restriction (maf).
I feel that the MAF has many other advantages. I feel that fueling is far more accurate. Its easier to tune out more of my cam bucking. It handles changes in weather easily. I can pass emissions, Misfire DTCs and counts work, etc.
I have a ported MAF, so the restriction is not an issue, and since ive tuned it, my open loop tune has been far more consistant than speed density.
Old 05-19-2006, 11:19 AM
SmokingWS6's Avatar
Originally Posted by white2001s10
"A good tuner (with added work) can adjust the MAF table until equal power (to a SD tune) is achieved on a dyno,
but the SD tune will run faster on the track still.
Thankyou!!!
And since we can tune maf's, at least those of us that attempt it. We can now change out mafs to larger more unrestricted units, so that shouldn't be an issue.
Old 05-19-2006, 04:00 PM
ringram's Avatar
Nice balance of opinion.
I prefer SD as stock 75mm maf is a restriction. I dont see the point with the larger ones. They still restrict flow over an open pipe, but I do understand the advantages for flexibility etc.
Old 05-19-2006, 04:02 PM
GuitsBoy's Avatar
This is a good way of looking at it. My biggest reason for going back to open loop MAF was that it helps aleviate cam bucking - atleast partially.
Old 05-19-2006, 05:43 PM
txhorns281's Avatar
Originally Posted by SmokingWS6
Thankyou!!!
Before we get all excited, I'm not sure how qualifiable what you quoted is. How can we keep enough things consistent to where you will know that it's the SD operation making the car run quicker down the track? I know in my experience, I've had both modes very well tuned, both modes making very similar dyno #s (which dyno inconsistancy alone could cause the disparity) and both modes running ballpark equally performancewise down the track and against numerous other vehicles from rolls on the street. There was never a hands-down, noticeable increase in performance. B/W either mode, I still kicked the car's asses (or lost to) that I always did, and by the same amount each time, and it was definitely not b/c of a lack of quality tuning
Usually when you have the case when one feels better than the other, it's b/c one of the modes is not properly tuned. But if you have them both inline, I'd like to see someone do a "blindfold" test and point out which is which. Come to think of it, that would be a pretty sweet deal since you'd have a 50/50 chance, though I'd be willing to wager that our "blindfoldee" wouldn't be terribly confident in deciding either way.
Old 05-19-2006, 09:38 PM
SmokingWS6's Avatar
In a boosted or large displacement application sometimes it becomes necessary to use a larger diameter maf if you wish to retain one due to frequency limitations. That's the main reason I bring up being able to upgrade maf's.
Personally I use a ported stock maf. I've experimented making runs with it removed and in place. I actually ran a tad bit slower with it removed, but as stated a lot of it has to do with the tune. AFR was mid 13's with it removed so that would explain the difference. It was rather cool outside and I had SD tuned it in summer heat.
BTW, just noticed you upgraded to a zo6. Any goodies under the hood?
Old 05-19-2006, 10:15 PM
gameover's Avatar
I think you'll find the 65-70mm hole in the intake manifold more of a restriction than an 85mm MAF
Old 05-20-2006, 03:44 AM
ringram's Avatar
... which is why I have a PT otrcai on the way
Old 05-20-2006, 04:45 AM
txhorns281's Avatar
LOL... this one's all for show baby... Rims, HIDs, and a few simple boltons
Old 05-20-2006, 06:36 AM
gameover's Avatar
i meant the area behind the throttle body. but yeah Mark's CAI is a good thing
In all the testing i've seen, the difference between SD with the GTS intake pipe and the VZ 85mm MAF is zero (even on small-medium cammed cars).
if at WOT your MAP is within 1-2 of Baro then the intake is not the problem. I've seen tests that move a vac gauge along the intake and i can tell you that certainly the 70mm MAF *IS* a restriction even on a stock LS1, but the 85mm MAF moves the point of restriction to the TB and/or the intake manifold inlet section. In the pre Monaro CAI days the old style VT airbox was worse than the MAF. Who would have thought that a sub $20 airbox and creative use of a 65mm holesaw would flow better than the best HSV could come up with at the time...
Even on 4-6 psi boosted cars the 85mm MAF is not the major bottleneck.
The VZ style 85mm MAF is readily availble now in Australia, which is a totally different story to a couple of years ago when "MAFless fever" was in full swing
We regularly see s/c LS2's 6-9psi with 320+ rwkw still using the MAF. 2bar isn't far away but it's not the walk in the park the LS1 was that's for sure...
Chris...
Old 05-20-2006, 11:00 PM
Bink's Avatar
Nah,.......you'll get the itch.
Then...the mods will start!
Old 05-20-2006, 11:43 PM
  #32
txhorns281's Avatar
Hey Bink, long time! I've got a bigger itch for some real estate so the car will have to be one the backburner for now! And to contribute more to this thread:
https://ls1tech.com/forums/showthrea...09#post4856709
Old 05-21-2006, 01:49 AM
  #33
LSs1Power's Avatar
We are seeing 13psi with my car and still running a MAF with no problems... What would SD do for me?
Old 05-21-2006, 09:33 AM
  #34
Red99C5's Avatar
Originally Posted by Darkness
Do F1 motors have a MAF? No
Is F1 motors driven on the street? And is the FITECH? NO and NO.
Most people go with SD for when they have reached the flow capacity of the MAF and need more air flow. IF your motor isn't flowing more CFM of air than the MAF can flow, then there is no advantage.
Old 05-22-2006, 09:48 AM
  #35
critter's Avatar
And some go with SD because it is the latest buzz, and having put the effort and energy into it are loath to admit they wasted their time ...
Old 05-22-2006, 10:49 AM
  #36
Gordy M's Avatar
During a talk with an ECM engineer, he said GM used SD for OBDI, MAF w/SD back up for OBD II, and only MAF planned for OBD III. Better practice with MAF tuning.
Old 05-22-2006, 11:32 AM
  #37
WS6FirebirdTA00's Avatar
Disadvantages of SD tuning (now that I have seen major weather changes on a daily driven basis)
-Lean start up with SD
-Part throttle/low flow fueling over corrected for IAT readings
Driving around now with the cam in the car, a tune on a cool day will make the car lean on a hot day (which I thought was odd) which makes it buck and it is a pain in the ***.
Old 05-22-2006, 11:35 AM
  #38
GuitsBoy's Avatar
Yes, this is the case with my car as well.
Old 05-22-2006, 01:12 PM
  #39
white2001s10's Avatar
edited due to technical errors.
my mistake.
Old 05-22-2006, 01:29 PM
  #40
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
Just because you didn't see it doesn't mean it isn't there.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Quick Reply: Advantages/disadvantages of SD?
