1.5 or 1.6 rockers
Old 05-04-2006, 08:02 PM
ls1charged's Avatar
Default 1.5 or 1.6 rockers
hey just wanted to know whats the better way to go, 1.5 or 1.6 roller rockers, what kind of gains can u see between the two and what kind of idle difference is there between the two, let me know what u guys know or have found from experience, thanks
Old 05-04-2006, 08:28 PM
96capricemgr's Avatar
depends on future plans and if you think there will be an idle difference you are thinking too hard.
Old 05-04-2006, 08:40 PM
ls1charged's Avatar
thats what i heard,( idle diff.) thats why i asked.
Old 05-05-2006, 09:40 AM
ls1charged's Avatar
Anybody?
Old 05-05-2006, 10:31 AM
the_merv's Avatar
I have never heard of any idle difference, then again I have a Cam, so it is completely tuned different. 1.6's will get you appx. 15 rwhp. They are a definate inprovement from the stamped steel rockers, they move alot easier. Actually pivot instead of slide.
Old 05-05-2006, 10:35 AM
ls1charged's Avatar
im gonna have a cam too, im doing a complete rebuild of my motor, stock rockers are 1.5's right?,but there not roller right?, how much of a gain could i see if i got 1.5 RR'S?
Old 05-05-2006, 11:10 AM
the_merv's Avatar
You mean 1.6RR's... appx. 15 rwhp, and a full-roller valve train, which is alot better than the standard Stamped Rockers. You will be able to get higher RPMs and build more power when you are up there over the stock ones. That depends on the Cam also...
Old 05-05-2006, 11:14 AM
sdm1234's Avatar
no he means 1.5 roller rockers. he's asking if there will be an improvement with the rollers instead of the factory stamped rockers.
Old 05-05-2006, 11:19 AM
the_merv's Avatar
With 1.5's, I would say a more stable and easier moving Valve Train. The 1.6's will open up more power capability.
Old 05-05-2006, 12:04 PM
ls1charged's Avatar
exactly thank you, so would it be worth it to get the 1.5 RR's or should i pay the extra $ to get 1.6's?
so knowbody has noticed a diff. in idle, or more of a lope?
Old 05-05-2006, 12:31 PM
the_merv's Avatar
I would get the 1.6's. They really don't change anything with idle..
Old 05-05-2006, 12:53 PM
sdm1234's Avatar
Get the 1.6RR's only if you plan on getting a cam eventually that will support 1.6's.
Old 05-05-2006, 01:13 PM
ls1charged's Avatar
its going to be something like a 224/230 cam.
Old 05-05-2006, 10:05 PM
1989GTA's Avatar
If you have the clearance than by all means the 1.6RR's. Remember lift is your friend when searching for horsepower.
Old 05-06-2006, 11:05 AM
ls1charged's Avatar
a lil off topic but does anybody know where u can get valve springs tested so i can make sure there rated to what there supposed to be?
Old 05-06-2006, 12:33 PM
Captainofiron's Avatar
The 1.6 ratio open up the valve usually 30-50 thousandths of an inch more than the 1.5 so its bearly more, it will definitly not affect the sound of your idle, alot of people report a difference in idle because they dont set their valve lash correctly and the poor idle is because of the change in the lash, not the higher lift on the valve.
Old 05-06-2006, 12:37 PM
You can buy the tool from a speed shop and do it your self or go to a machine shop and see if they have the tool, its called a valve spring tension or pressure tester or if you are looking to see how much the valve goes down then you need a valve spring height micrometer
Old 05-06-2006, 04:16 PM
ls1charged's Avatar
ahh, thanks
Old 05-06-2006, 05:18 PM
LT1BRN's Avatar
do the valve covers need to be changed?
Im installing hot cam kit that inclueds the 1.6rr's, do i need to get new valve covers?
Old 05-06-2006, 05:26 PM
94EvilZ28's Avatar
No you can clip out the inside part of the covers and they will work. No need to buy new ones...
Quick Reply: 1.5 or 1.6 rockers
