65 Chevelle Swap pictures
Old 04-19-2006, 03:52 PM
65chevellels1's Avatar
Default 65 Chevelle Swap pictures
Here are some pictures of my LS1/6speed swap into my 1965 Chevelle.
More pics to come.. (engine is being re-built HE HE)
Old 04-19-2006, 04:29 PM
Pictures of engine build:
FORGED Eagle H-Beam Rod's
Forged Diamond Pistons
Polished LS6 intake
Old 04-19-2006, 04:46 PM
FastTrackDF82's Avatar
Envy is a sin right?
I love the 64/65 chevelle's. Nice work.
Old 04-19-2006, 05:04 PM
pist0lpete's Avatar
Which engine mount adapters are you using?
Old 04-19-2006, 05:14 PM
THANKS FASTTRACK!
I originally built my own engine mounts however i ran into some oil pan/steering clearance issues... Since the motor has been out I bought the Street and Performance adaptors and hopefully that will help out the clearance problems when it goes back together
Old 04-19-2006, 05:21 PM
Stu Cool's Avatar
Great looking Chevelle, looks like a killer sleeper to me.
Pat
Old 04-19-2006, 05:41 PM
Hey, thanks! Im gonna keep the sleeper look for a while.. I have been running 2 very quiet 3" mufflers with dual 3" exhaust.. and then when i want it loud I use www.not-a-sponsor.net electronic exhaust diverters.
eventually however I would like to go for more of a pro-touring look whenever the $$$ permits.. Like this pic:
Old 04-19-2006, 09:17 PM
maro67's Avatar
man thats badass those chevelles rule man cant wait to see that thing all finished up.
Old 04-19-2006, 09:31 PM
stealth71's Avatar
Has it always been a manual car? If not what pedal setup did you use?
Old 04-19-2006, 09:50 PM
pist0lpete's Avatar
Thanks let us know how it works out with the S&P plates as far as clearance issues. Great looking car man I can't wait till my 67 has the LS1 between the frame rails.
Old 04-19-2006, 10:23 PM
Hey thanks guys for all the compliments.. The chevelle originally came with a 283 with a 2 speed powerglide
So what i did was used the factory camaro/firebird clutch and brake pedal assembly..... It did take some modifications and cutting to make it fit, but it actually worked great!
Old 04-19-2006, 11:08 PM
aussie craig's Avatar
unreal just what i hope to do are 65 chassis same as 1967 ? what model sump oil pickup etc did you use and are motor / swap mount supplyer on web any info is good, hard to find people with knowledge of this swap here in australia
Old 04-20-2006, 12:11 AM
Hey, I am not sure about the 65 to 67 frame comparison.. However i would think they are very similar. The best place to go for information is Street and Performance... www.hotrodlane.cc they know there stuff with these swaps.. The oil pan and pickup tube I modified and TIG welded myself, however Street and Performance will provide this service as well.. The mounts are street and performance as well.. Hope this helps! Let me know if ya have any more questions
this is a link for a install that Street & Performance did into a 65 chevelle.. good resource http://www.hotrodlane.cc/Streetstori...s1chevelle.pdf
Old 04-20-2006, 12:53 AM
thanks i appreciate that info will get back to you
Old 04-20-2006, 08:27 AM
More pictures of the engine build last night!
Nice Port job on the PRC LS6 heads!
Old 04-20-2006, 08:35 AM
stealth71's Avatar
So is that the clutch pedal assembly from the donor car or an old school camaro pedal setup? How did you go about mounting the clutch master? I have to do this in a couple weeks so I'm trying to figure it out. Have you done you harness yet?
Thanks,
Mike
Old 04-20-2006, 08:40 AM
Hey, the pedals came of out the 2000 trans am.. We just made our own bracket and mounted the master right to the firewall... using that pedal assembley kinda locates it for you for the geometry to work correctly. The harness that I used was made by Painless and it worked quite well. Requires a 1998 computer though.. Let me know if you need more info!
Old 04-20-2006, 01:47 PM
elesquan's Avatar
I tried to use the S&P mounts on my '67 el camino, but they did not work for me. (They sold for almost as much as i paid for them on ebay though!)
I used the stock f-body accessory drives, and the alternator hit the steering gear box with the S&P mount set up. I was also restricted on the location of the motor/trans as I used the firewall and transmission tunnel out of the '98 camaro donor car and needed the shifter to be in the right spot for the console.
I welded my own mount set up on the frame, and used the camaro motor mounts
If you need any pics of the mount set up I made, Just PM me.
I love your chevelle! It is my favorite year too. Good luck.
Old 04-20-2006, 07:11 PM
PM sent!
Old 04-20-2006, 07:16 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Cool
Hello again..great pics....good selection of vehicle..those chevelle's look cool...O yeah, def. go Pro-Street.....
Quick Reply: 65 Chevelle Swap pictures
