pros and cons to torque strap?
Old 08-28-2002, 06:18 PM
Satan's Angel's Avatar
Default pros and cons to torque strap?
I had a custom exhaust made, and it hits the floor just a bit when i launch the car. I was thinking of possibly putting a torque strap on the car to correct this. Is there any side effects to doing this...is so can you help me out.Thanks in advance guys!
Old 08-28-2002, 07:20 PM
Slow Z28's Avatar
Default Re: pros and cons to torque strap?
PROS-
1.)Keep my y-pipe from banging
2.)probably the reason i can pull the driver's side tire on launches <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
NEGS-
1.)possibly cause some KR if you don't mount it properly and the metal rachet part hits the k-member(if thats how you mount it)
I did it and it's worth it to me for the hooker y-pipe for the LT's. just make sure you get one strong enough to handle the stress. a friend already broke his
Chris
Old 08-28-2002, 07:44 PM
CarMan's Avatar
z28kid98,
I'd like to try the torque strap too. Where can I go for some instuctions or pictures, etc.
Thanks,
Carmen
Old 08-28-2002, 08:25 PM
Slow Z28's Avatar
well, for pictures try putting "torque strap" into the search engine above and search this forum.
i just went to ace hardware and bought a few to try out. i ended up getting one at a car show. be sure it's a rachet strap type, not just the pull type one. the rachet strap allows you to really get it tight. be sure it's not too long though, and be sure to get one strong enough to hold the motor power like i said before. i got one and i knew it wasn't strong enough. thing was thin as paper. good luck!
Chris
Old 08-28-2002, 09:07 PM
Thanks Z28kid98, looks like a nice little project for this weekend!
Old 08-28-2002, 10:25 PM
DriveATransAm's Avatar
what z28kid said.
i got some nasty knock retard with it setup two different ways. i ended up just not putting it back on.
Old 08-28-2002, 10:30 PM
ROB'S SS's Avatar
another neg. is hafting to get under the car to tighten it every couple weeks. i cant keep mine tight <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> i think im going to go with poly mounts when i do my tranny
Old 08-28-2002, 11:04 PM
FAST LS1's Avatar
Mine stays pretty tight, tight enough for the y-pipe to never bang anymore. The way I put my ratchet strap on no metal touches metal.
http://photos.yahoo.com/bc/ttudru/vw...12.jpg&.src=ph
Old 08-28-2002, 11:07 PM
hey fast, what do you have it attached to on the motor? i tried mine similair to that, then tried mounting to the back of the K member.
Old 08-28-2002, 11:09 PM
FAST LS1's Avatar
I have the actual nylon part wrapped around the lower alternator bracket, then back though the hook. It's a cast bracket so it's pretty strong.
This pic is a little better, but not much.
http://photos.yahoo.com/bc/ttudru/vw...11.jpg&.src=ph
<small>[ August 28, 2002, 11:13 PM: Message edited by: FAST LS1 ]</small>
Old 08-28-2002, 11:17 PM
DrkPhx's Avatar
A engine torque strap will only minimize the y-pipe from banging, but won't eliminate it. My y was banging bad, so I found the wear spot on the floorboard where it was hitting, and wedged a piece of metal wrapped in foam between them. Not only did it get rid of the banging and false KR, it also works as an effective torque strap.
Old 08-29-2002, 01:08 PM
2000Firehawk's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1852756521 <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old 08-29-2002, 04:10 PM
BurnOut's Avatar
How about something like this: http://store.summitracing.com/global...e/cee-4010.jpg ??
That one's for a Mustang, but there has to be a way to do something similar on the F-cars. I'm not a big fan of the ratchet straps; I just dont like the idea of the loose end of the strap flopping around and maybe getting caught in a fan, belt, etc...
Also, I'm looking for something that is a little cleaner-looking.
Not to be insulting; I just don't like the look of a nylon strap under the hood.
Old 08-29-2002, 04:34 PM
FAST LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BurnOut:
<strong>Also, I'm looking for something that is a little cleaner-looking.
Not to be insulting; I just don't like the look of a nylon strap under the hood.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Haha, yeah the ratchet strap does look ghetto. I don't mind though cause you can only see it when your under the car, and I'm cheap <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> An adjustable metal tierod like the one for that mustang would be nice though.
<small>[ August 29, 2002, 04:36 PM: Message edited by: FAST LS1 ]</small>
Old 08-29-2002, 05:13 PM
Slow Z28's Avatar
<strong>How about something like this: http://store.summitracing.com/global...e/cee-4010.jpg ??
Not to be insulting; I just don't like the look of a nylon strap under the hood.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well, obviously you have to "tie up loose ends" so that doesn't happen. you have to get one with the right length where you don't have excess material. And, like the other guy said, you can only see mine when you are under the car. And it's black, so you can barely see it even then. I like the Buick GN guys torque strap. A metal rod would be cool, but i need "some" flexibility to not vibrate the car too much.
Chris
Old 08-29-2002, 07:54 PM
justin sutton's Avatar
If someone comes up with a torquestrap that everyone likes I can build it.
Quick Reply: pros and cons to torque strap?
