The best ways to lighten a 4th gen F body.
Old 04-02-2006, 04:43 PM
blackedoutbird's Avatar
Default The best ways to lighten a 4th gen F body.
Where are some of the best places to start after removing AC lines, hoses, condenser, and the AIR pump?
Old 04-02-2006, 04:53 PM
urbanhunter44's Avatar
You can ditch the rear seats if you want (10 pounds maybe), put in lightweight carpet (30 pounds I heard), and get rid of all the sound insulation (gotta be 20 pounds worth of it).
Old 04-02-2006, 05:07 PM
Renegade's Avatar
Don't forget the spare tire/jack... obviously one of the first things to go. I know there is a write-up somewhere abouts with a list of everything that can be removed, and it's weight. But I don't think it's on LS1tech.
Old 04-02-2006, 05:12 PM
zigroid's Avatar
https://ls1tech.com/forums/drag-racing-tech/17319-weight-reduction-list.html
Old 04-02-2006, 06:30 PM
I don't think I'd remove the spare tire/jack if the car is a daily driver. Eventually you'll need it.
Old 04-03-2006, 12:43 PM
ToxicFormula's Avatar
definetly if daily driven do not remove the spare tire and jack cause its better to be safe than sorry. but when you go to the track, if you know someone who is gonna be there spectating you can take it out at the track or if you're going alone, take it out before going to the track
Old 04-06-2006, 01:00 AM
the_merv's Avatar
Depends on the Chassis you start with. Mine weighed 3350lbs, and that was stock Hardtop. I removed the Smog Pump, AIR Stuff, Rear Seats, shortened the exhaust, and removed the AC System. I upgraded to LS1 Big Brakes, and Eiback springs, so all the weight came back. Depends on what you do..
Old 12-16-2011, 05:13 PM
tarponhunter428's Avatar
I removed ac compresor.ac lines changed to a tubular k member took out factory seats put in one corbeau racing seat. But then I put in a Dana 60 rear and ended up only losing 30 lbs.
Old 12-16-2011, 05:29 PM
robsquikz28's Avatar
Holy 6 yrs ago....Lmao
Old 12-16-2011, 05:44 PM
transbird95's Avatar
Despite the old thread, Welcome aboard!
Old 12-18-2011, 01:11 PM
Rob94hawk's Avatar
Can't knock a new member that actually used the search function.
Welcome.
Quick Reply: The best ways to lighten a 4th gen F body.
