fastest ls2??
Old 03-12-2006, 04:16 PM
8 second mod
Noyzee's Avatar
Thumbs up fastest ls2??
who has the fastest stock cube ls2 or atleast stock bore size?
who is making the most power on the ls2?
Old 03-12-2006, 04:28 PM
Nate_Taufer's Avatar
Probably soon to be you there nitrous fiend. Look forward to seeing you break the record if there is one though.
Nate
Old 03-12-2006, 04:41 PM
8 second mod
Noyzee's Avatar
Nate
hahahaah, so not any real fast ls2's yet??
i think vett dr has a pretty bad ls2 running. not sure on cubes tho
be nice to grab the record again tho
Old 03-12-2006, 05:30 PM
Tenured Member
Timmy2Stage's Avatar
The fastest Nitrous LS2 is the Z28 that I built. Times are in my Sig. It should be the fastest this year too. I will have at the track soon and I will see to it that the atomic bomb get's sprayed at this car.
Old 03-12-2006, 05:36 PM
With about another 150 hp more nitrous that is a solid 8 second car. Pill it till ya kill it man.
Nate
Old 03-12-2006, 05:59 PM
InconFormula's Avatar
Sorry guys Mike Browns stock ls2 block with stock ls1 crank has gone 8.76@159, you better spray about 500 to keep up!!
Old 03-12-2006, 08:56 PM
ws6sojuiced01's Avatar
wow
Old 03-12-2006, 09:15 PM
gnx7's Avatar
Mike Brown's car is the single turbo car with a 4L80E correct? 8 second streetable car... yikes.
Old 03-12-2006, 10:04 PM
TwnTrboCE's Avatar
That's me. It actually went 8.78 Steve. Looking to do a little better this season after the good crank goes in.
Old 03-13-2006, 08:11 AM
8 second mod
Noyzee's Avatar
so your shooting for 8's this season. sounds like a sweet setup.
these blocks are pretty strong then. is yours resleaved? what size motor is it? 402,408 ?
incon, im looking for spray cars. i know i cant hang with a turbo car
Mr.Brown, is your block stock?
Old 03-13-2006, 08:21 AM
TwnTrboCE's Avatar
Yep. Stock caps and stock LS1 crank. ARP studs. Will find out in a couple weeks how it is doing on the inside when the crank goes in. Going to make more power and the stock crank is starting to worry me.
Old 03-13-2006, 08:26 AM
Quick Carl's Avatar
Mike,
That is awesome. I have a few questions. How long have you made that much HP on a stock block? Is the new crank going to be a stock stroke also? What, if any, problems have you ran into with the stock block ? Would you consider a 4.125" bore on a sleeved block.
The reason I'm asking is that we will soon be testing a new LS1 2nd gen. block (parts should cross over from your LS2) . We will be looking for, a throw everything you have at it, experienced tuner (so it gets a legit test) to test it. The fact that yours is street and strip is even better. It will be a 4.125" bore for turbo and nitrous applications. Max. bore will be 4.200" for strictly NA (no nitrous) applications. I will have to see when it's ready and who is going to test it. Your accomplishment with the current block sounds very interesting. Without giving any details of your set-up (unless you want to), what are your internals rated for?
Old 03-13-2006, 08:58 AM
8 second mod
Noyzee's Avatar
cool, im going to be running stock caps also. good crank,rods,pistions. stock bore, and a dual stage DP setup.
we'll see how she goes
id like to try to put up a fight for the fastest 402 on spray.
not sure im a contender, but i'll try. if the car ever runs again. lol
i have a lot done considering. my hood will be all mounted and sent out for paint, and the under hood will be ready for paint by the end of this week.
the back of the car is rewired, the doors are rewired, and the pannals will be going back on tonight. then its just running wiring for the head lights, fogs, and blinkers, then hooking it all up.
after that i need to get the motor in, and wired then the tranny mounted and im done.
geez, more work then i thought.
Old 03-13-2006, 09:23 AM
TwnTrboCE's Avatar
Originally Posted by Quick Carl
Mike,
I ran this combo all last season with no issues what so ever. The new crank will be stock stroke.
We use Callies Rods and Mahle race pistons in both cars. The new crank in mine will be a Forged Callies also. We also run stock caps on the Formula but it has a girdle. Something I think I will add when the crank goes in.
If you want us to test something for you we have no problems in doing so. We can put it in a 3,700+ lb car and take it to 1300+ FWHP or stick it in a 3,400 lb car and take it to 1600+ FWHP.
Noyzee,
It looks like your almost done. At least you can see the light at the end of the tunnel. Good luck to ya.
Old 03-13-2006, 09:30 AM
8 second mod
Noyzee's Avatar
Noyzee,
yhea, almost.
Old 03-13-2006, 09:31 AM
Tenured Member
I believe I said fastest NITROUS LS2.
I'll plum a direct -8an into the throttle body if I have to.
Old 03-13-2006, 09:34 AM
8 second mod
Noyzee's Avatar
haha, that will work!!
Old 03-13-2006, 01:01 PM
89lx-ls1's Avatar
Here shortly I will have some times but I am not on a camaro or a vette but we are betting on 9.90 to 10.0 on the motor and 8.5-8.7 on nitrous
Old 03-13-2006, 02:56 PM
8 second mod
Noyzee's Avatar
cool, 4 link set up?
im hoping for 8.9-8.7 once im dialed in. we'll see.
Old 03-13-2006, 04:30 PM
You had me confused because nitrous and fast dont go together...
Quick Reply: fastest ls2??
