Trouble codes PO418 & PO412
Originally Posted by JD_Z28
I have an 02 Z28 and these codes just popped up a little after installing an
STS kit. Does anyone know what the problem may be, thanks.
P0412 Secondary Air Injection Switching Valve A Circuit Generic OBDII Code
https://ls1tech.com/forums/pcm-diagnostics-tuning/209783-need-lookup-ses-code-look-here.html
Originally Posted by horist
http://www.obdii.com/codes.asp
if it asks you to regsiter.. the fields are dummy fields...
Type gibberish into them and it'll accept it... that's what I do
